Rep Power: 0 ![]() |
I noticed a strong grid orientation dependency while using interFoam with dynamicMeshing. the dynamicMeshing works fine (less initial mesh dependency) when the contact angle is > 40 degree (hydrohil), but deteriate severely when using contact angle close to 5 degree (want to simulation methanol flowing between a thin gap 0.19 mm composed of 2 plates)
following options have been tried so far 1) increasing maxRefinement from 2 to 6 --> no improvement 2) increasing maxCells --> no significant improvement 3) reducing refineInterval from 10 to 5 --> no significant improvement furthermore, i tried to change gradSchemes to pointCellsLeastSquares --> minor improvement but the issue persists. could anybody give me advice what else could be tried to avoid initial mesh dependency in the settings? |
dynamicmeshdict, interfoam |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
InterFoam and dynamicMesh fatal error | Rasmusiwersen | OpenFOAM Running, Solving & CFD | 11 | February 23, 2020 04:51 |
Problem with grid dependency test | alexrab89 | Siemens | 0 | June 19, 2013 04:36 |
Are the VOF results of interFoam grid independent | asaha | OpenFOAM Running, Solving & CFD | 1 | June 26, 2009 04:27 |
