December 6, 2021, 10:42 |
Problem with foamNewSource
Rep Power: 5 |
I'm trying to create a solver in /OpenFOAM/applications/solvers/electromagnetics using
foamNewSource App newSolver Code:
wmakeFilesAndOptions error: environment variable $WM_OPTIONS not set Code:
source /opt/OpenFOAM/OpenFOAM-9/etc/bashrc PATH=$PATH:/opt/OpenFOAM Code:
source /opt/OpenFOAM/OpenFOAM-9/etc/bashrc PATH=$PATH:/opt/OpenFOAM export WM_OPTIONS=linux64GccDPOpt Code:
WM_COMPILER=Gcc WM_PRECISION_OPTION=DP WM_PROJECT_USER_DIR=/home/ariedinger/OpenFOAM/ariedinger-9 WM_MPLIB=SYSTEMOPENMPI WM_OPTIONS=linux64GccDPOpt WM_ARCH=linux64 WM_LABEL_SIZE=32 WM_PROJECT=OpenFOAM WM_THIRD_PARTY_DIR=/opt/OpenFOAM/ThirdParty-9 WM_CC=gcc WM_LABEL_OPTION=Int32 WM_CFLAGS=-m64 -fPIC WM_LINK_LANGUAGE=c++ WM_OSTYPE=POSIX WM_PROJECT_VERSION=9 WM_DIR=/opt/OpenFOAM/OpenFOAM-9/wmake WM_ARCH_OPTION=64 WM_CXXFLAGS=-m64 -fPIC -std=c++0x WM_PROJECT_INST_DIR=/opt/OpenFOAM WM_LDFLAGS=-m64 WM_CXX=g++ WM_COMPILE_OPTION=Opt WM_PROJECT_DIR=/opt/OpenFOAM/OpenFOAM-9 WM_COMPILER_TYPE=system WM_COMPILER_LIB_ARCH=64 I don't know what configuration I'm messing up, so I'd appreciate some help! Thanks! |
environment variable, solve error, wmake |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
