Enquiry abt sixDoFRigidBodyMotionConstraint for 2 axes
Old   December 5, 2021, 21:30
Default Enquiry abt sixDoFRigidBodyMotionConstraint for 2 axes
TWB
quarkz is on a distinguished road
I am trying to simulate a body in 6dof which is fixed in location (sixDoFRigidBodyMotionConstraint point) but allow to rotate along the x and y axis.
I use:
fixedAxis
            sixDoFRigidBodyMotionConstraint axis;
            axis (1 1 0);
Is this correct? It's running and my results show that z axis is almost fixed:
Angular velocity: (0.0160949 0.0150073 5.55402e-12)
Or is it actually constrained to rotate along the (1 1 0) axis, which seems to be a bit different
Hope someone can help. Thanks.
quarkz is offline   Reply With Quote
Old   May 20, 2022, 03:13
TWB
Hi all,
I realised that if I use (1 1 0) axis, it will restrict motion along a line (1 1 0) axis.
Since what I wanted is dof along x and y, I should restrict along the xy plane:
NameofPlaneConstraint
sixDoFRigidBodyMotionConstraint plane;
normal (0 0 1);
Old   January 11, 2023, 03:36
TWB
I need to clarify that using the plane constraint allows x,y translation along the plane. However, allowing rotation along only x and y axes doesn't seem possible.
It's either rotations along x,y,z using point constraint, or only 1 axis using axis constraint.
Please correct me if I'm wrong.
Add axes to slice nskelly Tecplot 0 April 27, 2021 11:01
[General] Where can I change orientation axes in paraview? mykkujinu2201 ParaView 4 December 18, 2018 09:04
Rotation around 2 axes simultaneously Zeljko CFX 0 May 8, 2018 08:20
How to show axes around the domain in Fluent heksel8i FLUENT 0 December 2, 2013 07:10
[OpenFOAM] About the cube axes in Paraview rama ParaView 2 April 23, 2007 17:16
