high-frequency oscillations Overset
Old   December 5, 2021, 05:33
Default high-frequency oscillations Overset
acalado's Avatar
André
acalado is on a distinguished road
Greetings,
I am trying to simulate a simple 2D case of a flat plate at 45 degrees moving at constant speed (low Reynolds). I am using overset mesh grid with linear motion (constant velocity). Solver is overPimpleDyMFoam (v2012)
I have tried to validate the results and they seem ok in terms of order of magnitude, but there are some high frequency "noise" in the CL. I was wondering if anyone has any ideas on what may be causing this? I am attaching some pictures of the mesh and the resulting CL over time. I have tried to play with the numerics a bit (solution methods/tolerances/schemes) but no luck...
Thanks in advance!
Sapere aude!
acalado is offline   Reply With Quote
Old   March 16, 2022, 14:52
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
this is a typical problem from overset, in particular the openfoam implementation.
If you are using pimple, you can try to relax the final iterations, or setting momentumPredictor to false can also help. Be warned that the accuracy of your solution (continuity equation) may suffer, so use at your own risk..
louisgag is offline   Reply With Quote
high rotational speed centrifugal pump marekpl CFX 43 April 25, 2022 18:41
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 05:03
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
smaller PSD at low and high frequency spalartallmaras Main CFD Forum 1 April 18, 2020 10:34
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 08:32
