Re-initialize everything during run-time without restarting simulation
Old   December 2, 2021, 20:15
Default Re-initialize everything during run-time without restarting simulation
Nadun Palmada
Nadun19 is on a distinguished road
Hi
I am currently running moving mesh simulations using OpenFOAM 5.x on pimpleDyMFoam, and I am wanting to run an initial timestep (say 0.1) where I deform the mesh to a newer mesh but reset the flow (back to initial conditions) at 0.1s and continue simulation.
The reason why I need to do this is because I found that by starting the mesh at a highly deformed state I can spring the mesh back to an undeformed state and further deform to a highly deformed state along the simulation (slightly more deformed that the initial) without the mesh breaking. I have run the moveDynamicMesh application through the entire simulation without the mesh breaking. But if I start at the resting or undeformed state then the mesh breaks.
I tried adjusting the pimpleDyMFoam application such that the code after mesh.update();
phi = mesh.Sf() & Uf;
            if (mesh.changing() && correctPhi)
                #include "correctPhi.H"
            // Make the flux relative to the mesh motion
            fvc::makeRelative(phi, U);
            if (mesh.changing() && checkMeshCourantNo)
                #include "meshCourantNo.H"
            // --- Pressure-velocity PIMPLE corrector loop
            while (pimple.loop())
                #include "UEqn.H"
                // --- Pressure corrector loop
                while (pimple.correct())
                    #include "pEqn.H"
                if (pimple.turbCorr())
                    laminarTransport.correct();
                    turbulence->correct();
only runs after runTime.value() >= 0.2 , but this still resulted in extremely high velocities at the walls. I have also tried using manipulatePatchField and manipulateField swakFunctionObjects to adjust the field during run-time but this didn't seem to work.
Thanks
Nadun
Nadun19 is offline   Reply With Quote
moving mesh., pimple transient
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Transient run continues from last time (when startover is desired) bongbang CFX 2 March 23, 2015 00:05
Unexpected deltaT decrease in pimpleFoam simulation robyTKD OpenFOAM Running, Solving & CFD 9 June 27, 2014 07:52
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
