InterFoam for open channel: Time step divergence |
Zürich
Rep Power: 4 ![]() |
Hi everybody,
I'm trying to simulate open channel flow using InterFoam solver. When I set up the case with a simplified geometry (see below), the simulation runs without problem. Now for the real geometry, that includes a bend and a culvert section, the time step immediately diverges and the solution blows up. The boundary conditions for the two cases are identical and checkMesh results only in 1 failure (20 skewfaces) for the second case with complex geometry. Any idea what possibly went wrong during upscaling? ![]() Thanks a lot for your inputs, very much appreciated! |
interfoam, upscale, velocity and pressure |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
