Wall slip or Patch slip Boundary Condition
Old   November 25, 2021, 22:30
Default Wall slip or Patch slip Boundary Condition
mohammad
mostanad is on a distinguished road
Hi everyone,
I have a wall and I wanna make it stress free. So, as I know slip boundary condition can provide a wall with zero normal velocity and zero tangential gradient. But OF has two options for that:
1- boundary type wall, boundary condition slip;
2- boundary type patch, boundary condition slip;
Although this slip boundary condition acts like a symmetry boundary, but:
"It is very similar to the symmetry. Keep in mind that the symmetry is a boundary type, whereas the slip is a boundary condition which can be applied on boundary patches of type wall and patch respectively."
So which one, patch or wall boundary type, closer to a wall and far from symmetry?
mostanad is offline   Reply With Quote
Old   November 26, 2021, 06:41
mohammad
Any reply to help me in this regard will be appreciated.
Old   November 26, 2021, 06:45
Michael Alletto
mAlletto will become famous soon enough
For a slip condition I usually use a wall patch
mAlletto is offline   Reply With Quote
Old   November 26, 2021, 09:12
mohammad
Thank you Michael for your reply. Can you explain to me what is the difference?
Old   November 26, 2021, 14:57
Michael Alletto
https://cfd.direct/openfoam/user-guide/v6-boundaries/
Old   November 26, 2021, 18:49
Charles
Marpole is on a distinguished road
Did you say that you were modelling a wall boundary condition? Then it is wall type slip boundary condition.
Charles L.
Marpole is offline   Reply With Quote
Old   November 26, 2021, 21:13
mohammad
Yes, I want to consider it a wall without any penetration and stress-free. But the question is what is the difference between patch-slip and wall-slip BCs?
Old   November 27, 2021, 02:30
Charles
I understand that "slip" is a treatment to velocity at a boundary, where velocity component normal to the geometric patch is set to zero and velocity component tangential to the geometric patch is maintained.
The term patch in patch-slip has a special meaning. It is the type of boundary. Wall is another type of boundary. Patch and geometric patch are different.
For a wall type of boundary, it is a simple solid wall.
For a patch type boundary, it is more flexible. It can be used for inlet, outlet, though, with slip, this is not possible. But for some special cases such as a membrane where one or more species can pass through it, it needs a patch type slip boundary condition but not wall type. Patch-slip is rarely used.
Charles L.
Old   November 27, 2021, 06:20
mohammad
Thanks Charles for your nice explanation. So in terms of wall, there is no difference between patch-slip and wall-slip. However it is logical to use wall boundary type for my wall case. Anyway, I found wall-slip type rarely in tutorials.
But can you tell me what pressure condition should be considered for wall-slip? ZeroGradient or slip?
Old   November 27, 2021, 12:25
Charles
Great! For pressure boundary condition, zeroGradient and fixedFluxPressure are both popular. You can also use slip. I haven't tested it myself but believe it will give you the same results.
Charles L.
Old   November 27, 2021, 18:36
mohammad
OK. Thanks Charles. Your help is much appreciated.
Cheers,
Mohammad
Old   November 28, 2021, 18:28
mohammad
Sorry Charles for asking question again. In the tutorials,I can see a few cases using wall-slip BC. But there are multiple cases with patch-slip, like motorbike for front and back sides. When I look at these sides, the normal velocity is not completely zero:
while the U magnitude shows:
How this can be justified?
Mohammad
Old   November 29, 2021, 04:45
Michael Alletto
Is the wall normal direction y or z?
Old   November 29, 2021, 04:56
mohammad
Wall normal is actually the y direction. As you see, I have also shown y velocity.
Old   November 29, 2021, 05:08
Michael Alletto
Are you showing the boundary patches?
Old   November 29, 2021, 05:16
mohammad
Yes. These are the front and back planes.
Old   November 29, 2021, 06:54
Michael Alletto
From the figure it seems that the boundarie are too close to the body. If you move the boundaries away you will get smaller wall normal velocities
Old   November 29, 2021, 07:59
mohammad
Although it is showing a very low value, there should be no normal velocity for these walls. At the same time, this case considers patch-slip instead of wall-slip. Shoukd it be dependent of distance from body? What is your opinion?
Old   November 29, 2021, 10:07
Michael Alletto
Usually the disturbance to the flow caused by the body decreases with distance to the body
Old   November 29, 2021, 18:44
mohammad
But it is said that slip boundary condition considers zero normal velocity.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
