November 29, 2021, 22:12 |
#21 | |
mohammad
Rep Power: 12 |
Sorry for bothering you again. Can you please tell me your opinion about the above images? Thanks |
November 30, 2021, 01:59 |
#22 |
Charles
Rep Power: 10 |
I took a look at the motorBike case. Its front and back faces are patch type with slip velocity boundary and slip pressure boundary condition.
The results you showed has the max velocity (tangential) 20m/s and normal velocity 0.03m/s. For the non-zero normal velocity, I can only guess that the output in the code occurs not immediately after the boundary condition treatment. Immediately after the boundary condition treatment, mathematically, the normal velocity is set to zero. The code then will go on the next time step, where equations are solved iteratively. The output may occur after the iterations. This is my hypothesis and hope this is the case.
Charles L. |
November 30, 2021, 02:03 |
#23 | |
mohammad
Rep Power: 12 |
Thanks Charles for your nice reply. BTW, I have seen this behavior in so many slip cases, which seems to be normal. As you see the normal velocity is very low, and almost negligible. So You still think that it has a suitable approximation. |
November 30, 2021, 02:18 |
#24 |
Michael Alletto
Rep Power: 16 |
You have to consider that the system of equations is solved only up to a given tolerance
November 30, 2021, 02:27 |
#25 |
mohammad
Rep Power: 12 |
December 5, 2021, 06:46 |
#26 | |
Michael Alletto
Rep Power: 16 |
December 5, 2021, 07:11 |
#27 |
mohammad
Rep Power: 12 |
December 5, 2021, 07:35 |
#28 |
Michael Alletto
Rep Power: 16 |
Can you confirm that the result file of the figure you posted have zero wall normal velocities?
December 5, 2021, 07:53 |
#29 |
Michael Alletto
Rep Power: 16 |
December 5, 2021, 08:31 |
#30 |
Mark Olesen
Rep Power: 40 |
I can't remember if this was addressed in paraview-5.10 (or it is really easily addressable) - would be interesting if you could check.
December 6, 2021, 01:36 |
#31 |
mohammad
Rep Power: 12 |
December 6, 2021, 02:12 |
#32 |
Michael Alletto
Rep Power: 16 |
If the are not store as binary just open it with vim. It can read ascii files and also .gz files
December 6, 2021, 19:54 |
#33 |
mohammad
Rep Power: 12 |
June 7, 2022, 05:20 |
#34 |
Hassan Kassem
Rep Power: 18 |
Back to the original question, patch-slip vs wall-slip?
They could be exactly the same or completely different depending on the used models and domain. For example, in case of incompressible flow, with no heat transfer, which typically you would use simpleFoam or pimpleFoam. Your turbulence model would dictate if you would see a difference or not. This is simply due to the fact that the wall distance is needed in some turbulence model formulation such as SA and kOmega. In many cases, using a wall would not influence the results that much, since we typically try to set the boundary patches far away from the object of interest. |
August 24, 2023, 13:48 |
#35 | |
Ching Liu
Rep Power: 9 |
Hi Mostanad,
I met a similar issue: Slip gives non-zero velocity in the normal direction. Did you find the reason for that? Quote:
August 28, 2023, 06:55 |
#36 |
Joachim Herb
Rep Power: 22 |
The slip boundary conditions is internally a basicSymmetryFvPatchField and its values are set in https://github.com/OpenFOAM/OpenFOAM...#L97C12-L97C37
There the components normal to the faces are removed: https://github.com/OpenFOAM/OpenFOAM...chField.C#L110 But if I understand it correctly, this method is called *before* the U and the p equations are solved. After the pressure equation is solved, the flux phi and the velocities are calculated again. If the solution does not obey the boundary conditions perfectly, the velocitiy can have a non-zero component normal to the boundary. So has you solution converged? Do the normal values of the velocity change, if you reduce the residuals? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
