Boundary conditions for pressure in the interfom solver
Old   November 24, 2021, 02:25
Default Boundary conditions for pressure in the interfom solver
Dmitriy
Dmitriy_TSU is on a distinguished road
Hello!
My question is about computer modeling of the tank filling process. The geometry of the tank is depicted below. What kind of initial and boundary conditions should I specify in order to obtain the case when the pressure in the upper part of the tank (p1) is equal to 10^5 Pa (a constant value), and the pressure in the lower part (p2) is equal to zero (a constant value, providing vacuum conditions).
Thank you in advance!
Dmitriy_TSU is offline   Reply With Quote
filling tank, interfoam, pressure, p_rgh
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
