November 21, 2021, 13:51 |
Multi cylinder simulations in OpenFOAM
Subham
Hello
I am new to OpenFOAM. I am currently using it for running some simulations related to 2D flows past a single cylinder. Is it possible to perform simulations using pimpleFOAM or pisoFOAM when multiple cylinders (say 2 cylinders in tandem arrangement or 4 cylinders in square arrangement) are present in the domain? How can we run multi-cylinder flows in OpenFoam? |
November 21, 2021, 14:28 |
Hope the following links might help you
https://www.openfoam.com/documentati...und-a-cylinder http://www.ijesrt.com/issues%20pdf%2...ly-2018/19.pdf https://uis.brage.unit.no/uis-xmlui/...pdf?sequence=1 Good luck |
bluff body, multiple cylinders, openfoam v5.0 |
[blockMesh] Error while creating blockMesh for cylinder in OpenFOAM | malteradecke | OpenFOAM Meshing & Mesh Conversion | 0 | July 27, 2021 09:42 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 22:07 |
