November 19, 2021, 18:04 |
SHM layer problem on inside mesh
Alan w
Rep Power: 6 |
As part of debugging a multiRegion convergence problem, I am trying to improve the mesh. There are two regions, one of which is a heat exchanger. Its region is made by placing the point in mesh such that the outer domain is subtracted, leaving only the heat exchanger.
I am trying to create layers on the mesh, but when I activate layers in SHMDict, all I get is per the attached image, with no layers created. In the image showing a cross-section, the dimensions of the heat exchanger are 0.04 X 0.14 meters. I have a mesh enhancement box called 'refbox' specified; this box fully encloses the HX. Here is the text of SHMDict: Code:
castellatedMesh true; snap true; addLayers true; geometry { rad { type triSurfaceMesh; file "radiator.stl"; } refbox { type triSurfaceMesh; file "refbox.stl"; } refinementBox { type searchableBox; min ( 2.1 -0.5 -0.1); max ( 2.3 0.5 0.1); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { maxLocalCells 2000000; maxGlobalCells 4000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 1; //5 // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features ( { file "radiator.eMesh"; level 5; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces { rad { // Surface-wise min and max refinement level level (4 4); /*cellZone solid; faceZone solid; cellZoneInside inside;*/ radinlet {level (4 4); patchInfo {type patch;}} radoutlet {level (1 1); patchInfo {type patch;}} radwalltop {level (1 1); patchInfo {type wall; }} radwallbottom {level (1 1); patchInfo {type wall; }} radwall-lh {level (1 1); patchInfo {type wall; }} radwall-rh {level (1 1); patchInfo {type wall; }} } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { refbox { mode inside; //mode distance levels ((1e15 5)); //levels ((0.02 4)) } /*refinementBox { mode inside; levels ((1E15 5)); }*/ } locationInMesh (2.14 -0.20 0.11); allowFreeStandingZoneFaces no; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 1.2; //- Number of mesh displacement relaxation iterations. nSolveIter 185; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 4; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 5; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { radinlet { nSurfaceLayers 2; } radoutlet { nSurfaceLayers 2; } radwalltop { nSurfaceLayers 2; } radwallbottom { nSurfaceLayers 2; } radwall-lh { nSurfaceLayers 2; } radwall-rh { nSurfaceLayers 2; } } // Expansion factor for layer mesh expansionRatio 1.1; // Wanted thickness of final added cell layer. If multiple layers // is the // thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // is the thickness of the layer furthest away from the wall. // See relativeSizes parameter. finalLayerThickness 0.7; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.0001; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 85; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 25; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 4; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.2; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } Might it be because I only have the radiator face patches in the layer settings, rather than a single volume? Although I don't specify a volume, the meshing proceeded okay, other than the inability create layers. Any help resolving this problem will be greatly appreciated. |
November 20, 2021, 07:26 |
Yann
Rep Power: 29 |
Hi Alan,
I think your patch names are not properly defined. radinlet, radoutlet, etc are subregions of your rad geometry, and layers you be defined like this: Code:
rad_radinlet { nSurfaceLayers 2; } rad_radoutlet { nSurfaceLayers 2; } rad_radwalltop { nSurfaceLayers 2; } rad_radwallbottom { nSurfaceLayers 2; } rad_radwall-lh { nSurfaceLayers 2; } rad_radwall-rh { nSurfaceLayers 2; } Cheer, Yann |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 03:03 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
[snappyHexMesh] Snapping problem, non orthogonal faces | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2015 03:56 |
