momentumPredictor in PIMPLE (fvSolution)
Old   November 13, 2021, 03:02
Default momentumPredictor in PIMPLE (fvSolution)
WY
WUYing is on a distinguished road
Hi, I set "momentumPredictor yes;" in PIMPLE of fvSolution file and I use pimpleFoam. But when I check the output log file, I find it is the same with that of "momentumPredictor no;". So I don't know whether the momentum eq. is calculated at each time step. I am wondering is there any indicators in the log file to show that the "momentumPredictor yes;" has been applied in the calculation? Thanks!
WUYing is offline   Reply With Quote
Old   November 13, 2021, 16:18
Post
MNM
SHUBHAM9595 is on a distinguished road
Hi WY, As we dont have the info which version u r using......maybe try true/false instead of yes/no....
To chek whether the part of momentum predictor is being executed by solver....Try putting the following extra statement (bold one) in ur momentum predictor loop.
And don't forget to compile your solver..!!
if (pimple.momentumPredictor())
    solve(UEqn == -fvc::grad(p));
     Info<< "Foam is great" << endl;
    fvOptions.correct(U);
Now, every time it goes through the if loop, you should be able to have Foam is great in ur log file...
SHUBHAM9595 is offline   Reply With Quote
Old   November 13, 2021, 16:24
WY
Hi SHUBHAM9595, thanks for reply! I use OpenFOAM 8 in the cluster. So there is no any difference in the output log between "momentumPredictor true" and "momentumPredictor false" if I don't modify the source code of PIMPLE algorithm?
Old   November 13, 2021, 18:06
MNM
Definitely there should be a difference....
The info statement was just to be double sure that your solver is going through those lines....
The log file for a true/yes/on momentumPredictor usually have "Solving for Ux"...which is unavailable for its counterpart...
Old   November 13, 2021, 18:59
WY
I compare the outputs for momentumPredictor=yes and momentumPredictor=no, and find they are the same, so that's why I am confused here.
The part of log file for momentumPredictor=No is shown below and it also include "Solving for Ux" and "Solving for Uy".
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: sixDoFRigidBodyMotion
Selecting sixDoFSolver Newmark
Translational constraint tensor (0 0 0 0 1 0 0 0 0)
Rotational constraint tensor (0 0 0 0 0 0 0 0 0)
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
        Calculations will do 2 corrections
PIMPLE: Operating solver in transient mode with 2 outer correctors
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No MRF models present
No finite volume options present
Constructing face velocity Uf
Courant Number mean: 3.12577e-05 max: 0.00244642
Starting time loop
forces forces:
    Not including porosity effects
forces forceCoeffs:
forceCoeffs forceCoeffs:
forces forces write:
    sum of forces:
        pressure : (0 0 0)
        viscous  : (0 0 0)
        porous   : (0 0 0)
    sum of moments:
        pressure : (0 0 0)
        viscous  : (0 0 0)
        porous   : (0 0 0)
forceCoeffs forceCoeffs write:
    Cm    = 0
    Cd    = 0
    Cl    = 0
    Cl(f) = 0
    Cl(r) = 0
Time = 0.005
PIMPLE: Iteration 1
Restraint verticalSpring:  attachmentPt - anchor (0 0 0) spring length 0 force (-0 -0 -0)
6-DoF rigid body motion
    Centre of rotation: (0 0 0)
    Centre of mass: (0 0 0)
    Orientation: (1 0 0 0 1 0 0 0 1)
    Linear velocity: (0 0 0)
    Angular velocity: (0 0 0)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.0165777, No Iterations 14
GAMG:  Solving for pcorr, Initial residual = 0.0181884, Final residual = 0.0181884, No Iterations 0
time step continuity errors : sum local = 0.000182016, global = -1.24516e-07, cumulative = -1.24516e-07
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 3.26433e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.99801, Final residual = 6.48199e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00625807, No Iterations 16
GAMG:  Solving for p, Initial residual = 0.0174018, Final residual = 0.000121456, No Iterations 6
time step continuity errors : sum local = 1.22305e-06, global = -8.54508e-08, cumulative = -2.09966e-07
GAMG:  Solving for p, Initial residual = 0.0193525, Final residual = 8.79035e-05, No Iterations 16
GAMG:  Solving for p, Initial residual = 0.0126285, Final residual = 6.23357e-08, No Iterations 22
time step continuity errors : sum local = 6.32078e-10, global = -5.9136e-11, cumulative = -2.10025e-07
PIMPLE: Iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.46122, Final residual = 2.30174e-07, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0225461, Final residual = 4.41782e-07, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.0194297, Final residual = 9.36663e-05, No Iterations 16
GAMG:  Solving for p, Initial residual = 0.0128303, Final residual = 9.04912e-05, No Iterations 6
time step continuity errors : sum local = 9.15772e-07, global = -6.71101e-08, cumulative = -2.77136e-07
GAMG:  Solving for p, Initial residual = 0.0101681, Final residual = 9.78036e-05, No Iterations 14
GAMG:  Solving for p, Initial residual = 0.00937999, Final residual = 4.13711e-08, No Iterations 22
time step continuity errors : sum local = 4.20708e-10, global = -3.7605e-11, cumulative = -2.77173e-07
smoothSolver:  Solving for omega, Initial residual = 3.6852e-05, Final residual = 8.70431e-07, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 6.20835e-07, No Iterations 4
ExecutionTime = 0.42 s  ClockTime = 1 s
    sum of forces:
        pressure : (354.722 0.00226667 1.25337e-16)
        viscous  : (0.0967875 -9.5508e-07 -6.52158e-18)
        porous   : (0 0 0)
    sum of moments:
        pressure : (1.93686e-17 -3.29627e-17 2.12968e-06)
        viscous  : (-7.52294e-19 -5.23387e-19 3.28001e-06)
        porous   : (0 0 0)
    Cm    = 8.83213e-06
    Cd    = 579.296
    Cl    = 0.00369913
    Cl(f) = 0.0018584
    Cl(r) = 0.00184073
Old   November 13, 2021, 19:48
s1291's Avatar
s1291 is on a distinguished road
Not directly answering your question but try to use the residuals function object with the fields (p U) and see the output with and without momentumPredictor set to true/false.
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
Old   November 13, 2021, 20:25
WY
Hi s1291, thanks for reply! Do you mean to compare the residuals of p and U for momentumPrediction set true/false? Actaully, I have done this thing and the residuals are also almost same... I also attach the two residuals output for two cases.
Old   February 18, 2024, 09:21
geth03 is on a distinguished road
if you use pimple with nOuterCorrectors=1, it should run in piso mode. if momentumPredictor is off, you should not see any solving of velocity. so that is your proof.
geth03 is offline   Reply With Quote
fvsolution, openfoam 1806, pimple
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 27 August 12, 2024 11:15
PIMPLE – the value of the final under-relaxation factor Zbynek OpenFOAM 9 December 22, 2023 06:26
Error setting fvSolution PIMPLE xneop OpenFOAM Running, Solving & CFD 9 December 4, 2018 15:29
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
error while running modified pimple solver R_21 OpenFOAM Programming & Development 0 May 28, 2015 07:59
