November 12, 2021, 02:26 |
Create and submit job in queue for Openfoam
Zanh
Rep Power: 9 |
Hello everyone,
I am using OpenFOAM version 9 installed from openfoam.org in ubuntu (VirtualBox), and I have many cases to run so that I need a script to submit and it should run each case in queque. I have make script as follows: decomposePar mpirun -np 6 interFoam -parallel >log reconstructPar However, I don't what command I need to use to submit so that I could not check my script is working or not. Also, please add and/or correct my script if you know something wrong. Thank you very much for your help. Best regards, Zang |
SU2 shape_optimization.py parallel run using pbspro job scheduler | amitkamboj | SU2 Installation | 2 | May 19, 2015 19:06 |
