November 8, 2021, 02:04 |
How to use wideBandAbsorptionEmission model?
Bushra Rasheed
Rep Power: 5 |
Hi!
I want to use wideBandAbsoprtionEmission model in fvDOM and defined the radiation properties as: Code:
radiation on; radiationModel fvDOM; fvDOMCoeffs { nPhi 3; nTheta 5; tolerance 1e-3; maxIter 10; } // Number of flow iterations per radiation iteration solverFreq 5; constantAbsorptionEmissionCoeffs { absorptivity absorptivity [ m^-1 ] 0.01; emissivity emissivity [ m^-1 ] 0.01; E E [ kg m^-1 s^-3 ] 0; } absorptionEmissionModel wideBandAbsorptionEmission; wideBandAbsorptionEmissionCoeffs { lookUpTableFileName none; band0 { bandLimits (1.0e-6 2.63e-6); EhrrCoeff 0.0; species { CH4 { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } CO2 { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } H2O { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } Ysoot { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } } } } scatterModel none; sootModel none; Code:
There is no lookup table and the specie CO2 is not found Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object bands; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // band0 { bandLimits (1.0e-6 2.63e-6); EhrrCoeff 0.0; species { CH4 { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } CO2 { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } H2O { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } Ysoot { Tcommon 300.; Tlow 300.; Thigh 2500.; invTemp false; loTcoeffs (0 0 0 0 0 0) ; hiTcoeffs (.1 0 0 0 0 0); } } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
in /apps/OpenFOAM/OpenFOAM-v2106/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam [v100b:61889] *** Process received signal *** [v100b:61889] Signal: Segmentation fault (11) Has anyone used wideBandAbsoptionEmission model successfully? Thanks Bushra |
fvdom, radiation modelling, segmentation fault, wideband |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
interFoam wave propagation and explosion of Courant number and residuals | ChiaraViola | OpenFOAM Running, Solving & CFD | 1 | June 26, 2019 05:36 |
NEW turbulence TRANSITIONAL model | giammy92 | OpenFOAM | 3 | June 30, 2016 09:47 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 09:29 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
