Segmentation fault (core dumped) error in new solver |
Bushra Rasheed
Rep Power: 5 ![]() |
Hi Foamers!
I wanted to use this opensource solver https://gitlab.com/Jose_Moreno/openfoam_dom I have compiled it successfully on openfoam7 but when I try to use it for an application, I get this error: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : MultiRegionRadiationFoam Date : Oct 29 2021 Time : 14:25:46 Host : "CFD" PID : 909686 I/O : uncollated Case : /home/cfd/openfoam7/tutorials/heatTransfer/MultiRegionRadiationFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 *** Reading fluid radiation properties for region air Selecting radiationModel DORT Selecting phase Function Model HenyeyGreenteinsPhaseFunction Selecting extintionModel greyConstExt Solving optics... quadrature : Allocated 16 rays with average orientation: ray0 : omega : 0.785398 dir : (0.19509 0.980785 6.12323e-17) ray1 : omega : 0.785398 dir : (0.55557 0.83147 6.12323e-17) ray2 : omega : 0.785398 dir : (0.83147 0.55557 6.12323e-17) ray3 : omega : 0.785398 dir : (0.980785 0.19509 6.12323e-17) ray4 : omega : 0.785398 dir : (0.980785 -0.19509 6.12323e-17) ray5 : omega : 0.785398 dir : (0.83147 -0.55557 6.12323e-17) ray6 : omega : 0.785398 dir : (0.55557 -0.83147 6.12323e-17) ray7 : omega : 0.785398 dir : (0.19509 -0.980785 6.12323e-17) ray8 : omega : 0.785398 dir : (-0.19509 -0.980785 6.12323e-17) ray9 : omega : 0.785398 dir : (-0.55557 -0.83147 6.12323e-17) ray10 : omega : 0.785398 dir : (-0.83147 -0.55557 6.12323e-17) ray11 : omega : 0.785398 dir : (-0.980785 -0.19509 6.12323e-17) ray12 : omega : 0.785398 dir : (-0.980785 0.19509 6.12323e-17) ray13 : omega : 0.785398 dir : (-0.83147 0.55557 6.12323e-17) ray14 : omega : 0.785398 dir : (-0.55557 0.83147 6.12323e-17) ray15 : omega : 0.785398 dir : (-0.19509 0.980785 6.12323e-17) Time = 0.0005 Solving for fluid region air #0 Foam::error: ![]() #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::radiation::blackBodyEmissionRev::EbDeltaLamb daT(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::Vector2D<double> const&) const at ??:? #4 Foam::radiation::blackBodyEmissionRev::correct(int , Foam::Vector2D<double> const&) at ??:? #5 Foam::radiation: ![]() #6 ? in "/home/cfd/OpenFOAM/cfd-7/platforms/linux64GccDPInt32Opt/bin/MultiRegionRadiationFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/cfd/OpenFOAM/cfd-7/platforms/linux64GccDPInt32Opt/bin/MultiRegionRadiationFoam" Segmentation fault (core dumped) I have tried to copy a sample solver ,renamed it and used it in a tutorial to see if the error is reproduced with every new solver but the error could not be reproduced for the copied openfoam solvers. Please help me find the source of error. Thanks! |
#2 | ||
MNM
Rep Power: 9 ![]() |
The second line of your error gives you some hint
The next few lines of the error gives you the idea about the EXACT locations within the code where this might be happening Quote:
#3 | |
Bushra Rasheed
I have seen the original location of error. It points out to the following piece of code in blackBodyEmissionsRev.C: Code:
Foam::tmp<Foam::volScalarField> Foam::radiation::blackBodyEmissionRev::EbDeltaLambdaT ( const volScalarField& T, const Vector2D<scalar>& band ) const { tmp<volScalarField> Eb ( volScalarField::New ( "Eb", physicoChemical::sigma*pow4(T) ) ); if (band != Vector2D<scalar>::one) { scalarField& Ebif = Eb.ref(); forAll(T, i) { Ebif[i] *= fLambdaT(band[1]*T[i]) - fLambdaT(band[0]*T[i]); } volScalarField::Boundary& EbBf = Eb.ref().boundaryFieldRef(); forAll(EbBf, patchi) { fvPatchScalarField& EbPf = EbBf[patchi]; if (!EbPf.coupled()) { const scalarField& Tpf = T.boundaryField()[patchi]; forAll(EbPf, facei) { const scalar T1 = fLambdaT(band[1]*Tpf[facei]); const scalar T2 = fLambdaT(band[0]*Tpf[facei]); EbPf[facei] *= T1 - T2; } } } } return Eb; } ![]() |
dort, radiation fvdom, radiation model, segmentation fault, solver crash |
Segmentation fault (core dumped) | Kummi | OpenFOAM Programming & Development | 0 | April 23, 2021 10:28 |
Floating point exception (core dumped), running a new solver | Mahyar Javidi | OpenFOAM Running, Solving & CFD | 6 | April 7, 2018 12:43 |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 21:59 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
