What residual to look at if p is calculated twice?
Old   October 26, 2021, 06:01
Default What residual to look at if p is calculated twice?
Claudia
Clau.77 is on a distinguished road
Hey guys,
i have a question about the residuals of p_rgh / the logfile.
Solving for fluid region Luft
DILUPBiCGStab:  Solving for Ux, Initial residual = 5.52396048298e-05, Final residual = 5.52396048298e-05, No Iterations 0
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.000329795634347, Final residual = 2.73844961588e-06, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.000548108495771, Final residual = 4.51712127338e-06, No Iterations 1
DILUPBiCGStab:  Solving for h, Initial residual = 3.48039609994e-06, Final residual = 1.74374968305e-10, No Iterations 1
Min/max T:288.15 302.65
GAMG:  Solving for p_rgh, Initial residual = 0.00245483936325, Final residual = 1.19266184819e-05, No Iterations 3
time step continuity errors : sum local = 3.93180078034e-05, global = 1.02476345934e-06, cumulative = 1.02476345934e-06
Min/max rho:1.225 1.225
GAMG:  Solving for p_rgh, Initial residual = 0.000516682871768, Final residual = 7.25064390756e-05, No Iterations 1
time step continuity errors : sum local = 0.000239004260786, global = 1.03940496747e-06, cumulative = 2.06416842681e-06
DILUPBiCGStab:  Solving for epsilon, Initial residual = 0.000101066185136, Final residual = 4.76627361674e-07, No Iterations 1
DILUPBiCGStab:  Solving for k, Initial residual = 0.000142459907738, Final residual = 1.03597777104e-06, No Iterations 1
As you can see, p_rgh is calculated twice. As far as I understand, this is because I use nCorrectors=2, right? So my question is, at which value am I looking at if I want to plot the residuals. Only the last p_rgh entry or is the first one important as well?
Clau.77 is offline   Reply With Quote
Old   October 26, 2021, 06:14
s1291's Avatar
s1291 is on a distinguished road
1) Right, because you are using nCorrectors = 2, the pressure will be solved twice. More details can be found in this openfoamwiki blog.
2) I believe you can find many discussions in this forum explaining how residuals are computed. Yes, you need only the value at the first iterations.
You don't need to extract them manually, use the residuals function object for that purpose. Use foamMonitor script to plot them.
s1291 is offline   Reply With Quote
Old   October 26, 2021, 06:16
Claudia
Thanks for the fast reply!
chtmultiregion, logfile, ncorrectors, openfoam, residuals
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
