multiphaseEulerFoam Co number explosion where no dispersed phase exist |
October 19, 2021, 04:29 |
Rep Power: 8 |
hi all,
i am running a simulation with the reactingMultiphaseEulerFoam solver on OF version 7. i have one continuous phase and multiple dispersed phases in one system. i don't know why but for the largest droplet phase the velocity rises to really high values, the strange thing is that the volume fraction for that phase is zero right there. the stranger thing is that the CO number right there rises quickly, too. now, the question is: how does the Co-value increase when there is no dispersed phase with the high veloctiy? |
October 20, 2021, 09:51 |
Rep Power: 8 |
i examined the code and found out that Co for multiphase cases is calculated for each phase independently and also for the total flux. so the max value is then taken as Co_max in the end, which means it doesnt matter if there is one particular phase or not.
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
