October 15, 2021, 08:35 |
Overset mesh with no dregees of freedom
Manuel Fraga Seoane
Rep Power: 6 |
Hi Foamers. I am trying to use an overset mesh wit OpenFoam2106 for a boat simulation. I would like to constrain all degrees of freedom to achieve a smooth flow and then release the boat and let it move in Z axis and around Y axis (heave and pitch).
I have tried to edit the dynamicMeshDict deleting all joints (with no joints I guessed that all degrees of freedom would be restricted, but the simulation crashes in the first iteration) and even trying with the "null" type ("Cannot calculate the state of a null-joint" message appears). I would really appreciate some help. Does not matter if you know the solution of my problem or another way of doing what I expose. Thank you in advance. Manuel |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Overset Mesh error : no startcell found ! | Cris ZC | STAR-CCM+ | 4 | September 9, 2019 10:43 |
Is overset mesh required? | ahildershavn@yahoo.no | OpenFOAM Running, Solving & CFD | 2 | August 4, 2017 03:23 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
