Open channel flow with PisoFoam
Old   October 14, 2021, 01:46
Default Open channel flow with PisoFoam
Ibaraki
kraf is on a distinguished road
Hello! A beginner in OpenFOAM.
I want to simulate a inclined open channel using Pisofoam. I want different values for discharge with different slopes. I noticed in the tutorials that only U and P are specified as boundary conditions. In the tutorials the bed is flat so I wonder, what causes the movement of flow from the inlet to the outlet in that case.
Also, what type of velocity should I set in the inlet BC? Is it the depth averaged velocity? Is this velocity at the boundary changing with time or is constant until the end of the simulation.
Thank you for your help in advance!
(I'm using pisofoam because I want to simulate turbulent flow as final objective)
kraf is offline   Reply With Quote
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
Open channel flow with submerged outlet Fonta Fluent Multiphase 0 September 30, 2013 09:04
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Open channel flow motaba Main CFD Forum 4 March 26, 2011 04:22
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
