somaFoam - And plasma goes weee
Old   October 13, 2021, 11:29
Talking somaFoam - And plasma goes weee
Adrien
Destouches is on a distinguished road
Hi foamers,
Recently, I found this outstanding publication from an american team:
https://www.sciencedirect.com/scienc...10465521000229
Labelled as opensource and based on our beloved OF, somaFoam manages to solve Vlasov-Maxwell equations system (aka 'donoteventrytosolvemeyoumeagernobody') to simulate EM fields and ion/electron dynamic densities in a plasma.
I was eager to see if it was in the latest foam-extend but nope, no github nor DL references in the paper either. I tried to contact authors directly, no luck.
This forum never mentioned this solver before, so I assume the source code hasn't been released, unless somebody here corrects me ?
So many plasma codes seem to be locked in air-thight labs, that's a pity. By the way, did anyone here worked with picFoam ? https://www.sciencedirect.com/scienc...10465521000187
This one looks really promising as well.
Maybe my wet dream of a beam/plasma interaction solver will come true one day. Or at least, give me a good starting point to try to build it myself.
Cheers Foamers.
Destouches is offline   Reply With Quote
Old   October 23, 2021, 07:12
Eren
ErenC is on a distinguished road
There are probably thousands of user developed/modified solvers(Even I have 2 different modified solvers), OpenFOAM (both branches) cannot follow and give support for all of the solvers. That is literally impossible. Authors of the paper clearly shared to code in their paper (that we should be thankful), you just need to compile and use. You can search for "how to compile OpenFOAM solver".
ErenC is offline   Reply With Quote
Old   November 19, 2021, 05:55
Adrien
Hi Foamers,
Just a quick feedback on my plasmic investigations.
The solver picFoam works wonders. Its tutorials cover many configurations and with a few tricks, it allows me to work on beam optics just well.
A nice illustration: https://ibb.co/rFPLZns
So far, it validated gyration radii and Brillouin limits of my traps.
His creator, author of the above publication, more than being talented, is also a very kind person.
Have a nice one foamers.
Old   May 4, 2022, 17:05
Default somafoam
PlasmaCFD is on a distinguished road
good news, plasma foamers: https://github.com/vayyaswamy/SOMAFOAM
PlasmaCFD is offline   Reply With Quote
Old   October 15, 2022, 03:00
lilil
mgq920857776 is on a distinguished road
hello dear, how to install the somafoam? I cannot the somafoam
mgq920857776 is offline   Reply With Quote
Old   October 15, 2022, 03:01
lilil
hello dear, how to install the somafoam? I cannot the somafoam,please help me
Old   October 15, 2022, 07:47
Mostafa
mostafa kareem is on a distinguished road
Hello
Please , Could you help me installing the solver ,
I cloned the solver to Opt/ directory then I typed ./install , but i got the following error
Makefile:55: /opt/SOMAFOAM/etc/../wmake/rules/linux64Gcc63/c++: No such file or directory
make: *** No rule to make target '/opt/SOMAFOAM/etc/../wmake/rules/linux64Gcc63/c++'. Stop.
This system rpm command: rpm --force-debian
Building cmake 3.2.2
Package name : cmake-3.2.2
Package URL : http://www.cmake.org/files/v3.2/cmake-3.2.2.tar.gz
RPM spec file name: cmake-3.2.2.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package cmake-3.2.2
RPM file name : /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/cmake-3.2.2-linux64Gcc63DPOpt.x86_64.rpm
Making package cmake-3.2.2 using RPM.
Building package cmake-3.2.2 using SPEC file : cmake-3.2.2.spec. Optional args:
error: failed to create directory %{_srcrpmdir}: /opt/SOMAFOAM/metis/rpmBuild/SRPMS: Permission denied
Installing package: cmake-3.2.2
Uninstalling cmake-3.2.2 using RPM: cmake-3.2.2-linux64Gcc63DPOpt.x86_64
Installing cmake-3.2.2 using RPM file: /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/cmake-3.2.2-linux64Gcc63DPOpt.x86_64.rpm
error: open of /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/cmake-3.2.2-linux64Gcc63DPOpt.x86_64.rpm failed: No such file or directory
Done installing package
Building metis 5.1.0
Package name : metis-5.1.0
Package URL : http://downloads.sourceforge.net/pro...s-5.1.0.tar.gz
RPM spec file name: metis-5.1.0.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package metis-5.1.0
RPM file name : /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/metis-5.1.0-linux64Gcc63DPOpt.x86_64.rpm
Making package metis-5.1.0 using RPM.
Building package metis-5.1.0 using SPEC file : metis-5.1.0.spec. Optional args:
Installing package: metis-5.1.0
Uninstalling metis-5.1.0 using RPM: metis-5.1.0-linux64Gcc63DPOpt.x86_64
Installing metis-5.1.0 using RPM file: /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/metis-5.1.0-linux64Gcc63DPOpt.x86_64.rpm
error: open of /opt/SOMAFOAM/etc/../metis/rpmBuild/RPMS/x86_64/metis-5.1.0-linux64Gcc63DPOpt.x86_64.rpm failed: No such file or directory
+ wmakePrintBuild -check
no git description found
+ /bin/rm -f foam/Make/linux64Gcc63DPOpt/global.?
+ wmakeLnInclude foam
+ wmakeLnInclude meshTools
+ wmakeLnInclude OSspecific/POSIX
+ wmake libo OSspecific/POSIX
/opt/SOMAFOAM/etc/../wmake/MakefileOptions:36: /opt/SOMAFOAM/etc/../wmake/rules/linux64Gcc63/general: No such file or directory
make: *** No rule to make target '/opt/SOMAFOAM/etc/../wmake/rules/linux64Gcc63/general'. Stop.
/opt/SOMAFOAM/etc/../wmake/MakefileFiles:39: linux64Gcc63DPOpt/options: No such file or directory
make: *** No rule to make target 'linux64Gcc63DPOpt/options'. Stop.
wmake error: file 'Make/linux64Gcc63DPOpt/objectFiles' could not be created
+ wmake libso foam
+ decompositionMethods/AllwmakeLnInclude
+ wmakeLnInclude decompositionMethods
+ wmakeLnInclude metisDecomp
+ wmake libso decompositionMethods
+ wmake libso metisDecomp
+ wmake libso lagrangian/basic
+ wmake libso edgeMesh
+ wmake libso surfMesh
+ wmake libso meshTools
+ wmake libso finiteVolume
+ wmake libso finiteArea
+ wmake libso lduSolvers
+ dynamicMesh/AllwmakeLnInclude
+ wmakeLnInclude dynamicMesh
+ wmakeLnInclude dynamicFvMesh
+ wmakeLnInclude topoChangerFvMesh
+ meshMotion/AllwmakeLnInclude
+ wmakeLnInclude solidBodyMotion
+ wmakeLnInclude fvMotionSolver
+ wmakeLnInclude RBFMotionSolver
+ wmake libso dynamicMesh
+ wmake libso solidBodyMotion
+ wmake libso fvMotionSolver
+ wmake libso RBFMotionSolver
+ wmake libso dynamicFvMesh
mostafa kareem is offline   Reply With Quote
Old   June 29, 2023, 00:26
rosee
rose ttt is on a distinguished road
An installation procedure for somoFoam is posted here: https://github.com/vayyaswamy/SOMAFO...tion-procedure
I followed all the steps. However, after installation and source etc/bashrc, I typed plasmaSimFoam and it turned out command not found. I goes to ~/SOMAFOAM/bin/linux64GccDPOpt and found no exectable file plasmaSimFoam. That indicates that it did not compiled successfully. But I can not found err messages in install.log.
The file is too long, so I only post the begining and ending here:
*---------------------------*LTPS Installation Initiated*--------------------------------*
gcc -m64 -Wall -O3 -fPIC dirToString.c -o /home/zhiguo/SOMAFOAM-main/etc/../wmake/bin/linux64Gcc/dirToString
flex wmkdep.l
gcc -m64 -Wall -O3 -fPIC lex.yy.c -o /home/zhiguo/SOMAFOAM-main/etc/../wmake/bin/linux64Gcc/wmkdep
lex.yy.c:1386:17: warning: ‘yyunput’ defined but not used [-Wunused-function]
static void yyunput (int c, char * yy_bp )
lex.yy.c:1429:16: warning: ‘input’ defined but not used [-Wunused-function]
static int input (void)
RPM file name :
Additional flags :
RPM file name : /home/zhiguo/SOMAFOAM-main/etc/../metis/rpmBuild/RPMS/x86_64/cmake-3.2.2-linux64GccDPOpt.x86_64.rpm
Executing(%prep): /bin/sh -e /home/zhiguo/SOMAFOAM-main/metis/rpmBuild/tmp/rpm-tmp.V4OnBr
+ umask 022
+ cd /home/zhiguo/SOMAFOAM-main/etc/../metis/rpmBuild/BUILD
+ cd /home/zhiguo/SOMAFOAM-main/metis/rpmBuild/BUILD
+ rm -rf cmake-3.2.2
+ /bin/gzip -dc /home/zhiguo/SOMAFOAM-main/metis/rpmBuild/SOURCES/cmake-3.2.2.tar.gz
+ /bin/tar -xof -
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd cmake-3.2.2
+ /bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
Executing(%build): /bin/sh -e /home/zhiguo/SOMAFOAM-main/metis/rpmBuild/tmp/rpm-tmp.jBa36Z
+ umask 022
+ cd cmake-3.2.2
+ [ -n gcc ]
+ export CC=gcc
+ [ -n g++ ]
+ export CXX=g++
+ [ -n -m64 -fPIC ]
+ export CFLAGS=-m64 -fPIC
+ [ -n -m64 -fPIC ]
+ export CXXFLAGS=-m64 -fPIC
+ [ -n -m64 ]
+ export LDFLAGS=-m64
+ ./configure --prefix=/home/zhiguo/SOMAFOAM-main/etc/../metis/packages/cmake-3.2.2/platforms/linux64GccDPOpt
CMake 3.2.2, Copyright 2000-2015 Kitware, Inc.
C compiler on this system is: gcc -m64 -fPIC
C++ compiler on this system is: g++ -m64 -fPIC
Makefile processor on this system is: make
g++ is GNU compiler
Making dependency list for source file mapLagrangian.C
Making dependency list for source file changeDictionary.C
Making dependency list for source file mapFields.C
SOURCE=changeDictionary.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/dynamicMesh/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/changeDictionary.o
SOURCE=mapLagrangian.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/lagrangian/basic/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/sampling/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mapLagrangian.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/dynamicMesh/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/changeDictionary.o -L/home/zhiguo/SOMAFOAM-main/etc/../lib/linux64GccDPOpt \
-lfiniteVolume -ldynamicMesh -lmeshTools -lfoam -ldl -lrt -lm -o /home/zhiguo/SOMAFOAM-main/etc/../bin/linux64GccDPOpt/changeDictionary
Making dependency list for source file setFields.C
SOURCE=setFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setFields.o
SOURCE=mapFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/lagrangian/basic/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/sampling/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mapFields.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setFields.o -L/home/zhiguo/SOMAFOAM-main/etc/../lib/linux64GccDPOpt \
-lfiniteVolume -lmeshTools -lfoam -ldl -lrt -lm -o /home/zhiguo/SOMAFOAM-main/etc/../bin/linux64GccDPOpt/setFields
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/lagrangian/basic/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/sampling/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/mapLagrangian.o Make/linux64GccDPOpt/mapFields.o -L/home/zhiguo/SOMAFOAM-main/etc/../lib/linux64GccDPOpt \
-lsampling -lmeshTools -llagrangian -lfiniteVolume -lfoam -ldl -lrt -lm -o /home/zhiguo/SOMAFOAM-main/etc/../bin/linux64GccDPOpt/mapFields
*--------------------------*LTPS Installation Finished*----------------------------------*
rose ttt is offline   Reply With Quote
Old   June 29, 2023, 07:21
rosee
I found the error message as follows.
SOURCE=plasmaEnergyModels/eTemperature/efullImplicit/efullImplicit.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/basic/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/specie/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/reactionThermo/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/chemistryModel/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/efullImplicit.o
SOURCE=multiSpeciesPlasmaModels/multiSpeciesPlasmaModel/multiSpeciesPlasmaModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/zhiguo/SOMAFOAM-main/etc/../src/finiteVolume/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/meshTools/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/basic/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/specie/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/reactionThermo/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/thermophysicalModels/chemistryModel/lnInclude -IlnInclude -I. -I/home/zhiguo/SOMAFOAM-main/etc/../src/foam/lnInclude -I/home/zhiguo/SOMAFOAM-main/etc/../src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/multiSpeciesPlasmaModel.o
multiSpeciesPlasmaModels/multiSpeciesPlasmaModel/multiSpeciesPlasmaModel.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::multiSpeciesPlasmaModel::dElectronTempSource DTe(const Foam:siChemistryModel&)’:
multiSpeciesPlasmaModels/multiSpeciesPlasmaModel/multiSpeciesPlasmaModel.C:679:23: error: ‘const class Foam:siChemistryModel’ has no member named ‘dEChemSourceDTe’
pets = (chemistry.dEChemSourceDTe()())*plasmaConstants::A/W(eIndex_);
multiSpeciesPlasmaModels/multiSpeciesPlasmaModel/multiSpeciesPlasmaModel.dep:687: recipe for target 'Make/linux64GccDPOpt/multiSpeciesPlasmaModel.o' failed
make: *** [Make/linux64GccDPOpt/multiSpeciesPlasmaModel.o] Error 1
make: *** Waiting for unfinished jobs....
Old   March 14, 2024, 19:40
Default Unknown reaction type metastableTwoImpactArrheniusReaction
Simran Dixit
Simran is on a distinguished road
hey,
I have installed SOMAFOAM successfully, I tried to run the example - examples/helium-13.56MHz-1017/externalCircuit.
I encounter the error-
followed by a list of reaction types.
Anyone who ran these examples, please let me know where the error is.
I used plasmaSimFoam.
Simran is offline   Reply With Quote
Old   July 17, 2024, 07:53
ESI
ht2017 is on a distinguished road
did you run the examples in SOMAFoam yet?
ht2017 is offline   Reply With Quote
Old   July 17, 2024, 07:55
ESI
Originally Posted by Simran View Post
hey,
Could you run these examples in SOMAFoam succeed yet?
if "yes" please teal me how to do it. thank you so much!
