cristobal albarracin
Rep Power: 16 ![]() |
Dear Foamers,
I am trying to run a case with a rotor/stator configuration using either AMI or MRF, and tracking particles as well, using MPPICFoam and openfoam-8, but I run into an error that says MPPICFoam does not support moving meshes; however, the description in the user guide says it does. Does anyone know if openfoam-9 has solved this problem? Regards, Cris. |
Bas Nieuwboer
Rep Power: 13 ![]() |
I cannot find an indication that OF9 includes dynamic mesh capabilities. See the code of the main file: https://github.com/OpenFOAM/OpenFOAM...ParticleFoam.C
The ESI version (www.openfoam.com) does include the dynamic mesh capabilities for MPPIC. See the MPPICDyMFoam solver at https://www.openfoam.com/documentati...061951fa3.html |
Rep Power: 6 ![]() |
Could you share the error message ? |
ami, mppicfoam, mrf |
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 09:36 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Lagrangian particle tracking and cell size | Julian K. | CFX | 4 | May 27, 2014 11:35 |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 12:03 |
DPM particle tracking | parisa- | Main CFD Forum | 2 | June 15, 2011 05:12 |
