How to solve the error message "Foam::error::printStack(Foam::Ostream&)"
Old   October 11, 2021, 16:54
Default How to solve the error message "Foam::error::printStack(Foam::Ostream&)"
F
fran.cesc is on a distinguished road
Good day,
I am new to OpenFoam, so probably my mistakes are going to be obvious to some of you.
I am trying to simulate an external flow of water around a cylinder (2d).
I copied the tutorial Airfoil2d (simpleFoam) folder. I then imported a Fluent Mesh.
I changed just a couple of parameters here and there, but when I run the solver I get the below error message
Could anybody give me some help please?
Thanks a lot
  1. Control Dict
    application     simpleFoam;
    startFrom       startTime;
    startTime       0;
    stopAt          endTime;
    endTime         500;
    deltaT          1;
    writeControl    timeStep;
    writeInterval   50;
    purgeWrite      0;
    writeFormat     ascii;
    writePrecision  6;
    writeCompression off;
    timeFormat      general;
    timePrecision   6;
    runTimeModifiable true;
    functions
        momErr
            type            momentumError;
            libs            (fieldFunctionObjects);
            executeControl  writeTime;
            writeControl    writeTime;
        contErr
            type            div;
            field           phi;
        turbulenceFields1
            type            turbulenceFields;
            fields
                k
                epsilon
                nut
                nuEff
                R
                devReff
                L
                I
        mag1
            type            mag;
            field           turbulenceProperties:R;
            result          magR;
  2. Turbolence Properties
    simulationType          RAS;
    RAS
        RASModel            SpalartAllmaras;
        turbulence          on;
        printCoeffs         on;
  3. Transport Properties
    transportModel  Newtonian;
    nu              1e-06;
  4. U
    internalField   uniform (1.5 0.01 0);
    boundaryField
        inlet
            type            freestreamVelocity;
            freestreamValue $internalField;
        outlet
        walls
            type            noSlip;
        frontandback
            type            empty;
  5. p
    i
    nternalField   uniform 0;
    boundaryField
        inlet
            type            freestreamPressure;
        outlet
        walls
            type            zeroGradient;
        frontandback
            type            empty;
  6. nut
    internalField   uniform 0;
    internalField   uniform 0.14;
    boundaryField
        inlet
            type            freestream;
            freestreamValue uniform 0.14;
        outlet
            type            freestream;
        walls
            type            nutUSpaldingWallFunction;
            value           uniform 0;
        frontandback
            type            empty;
  7. nuTIlda
    boundaryField
        inlet
            type            freestream;
        outlet
            type            freestream;
        walls
            type            fixedValue;
            value           uniform 0;
        frontandback
            type            empty;
  8. Boundary of the polymesh
        walls
            type wall;
            physicalType wall;
            nFaces          28;
            startFace       43092;
        inlet
            type patch;
            physicalType inlet;
            nFaces          483;
            startFace       43120;
        outlet
            type patch;
            physicalType outlet;
            nFaces          117;
            startFace       43603;
        frontandback
            type empty;
            physicalType empty;
            nFaces          43406;
            startFace       43720;
  9. fvSchemes
    ddtSchemes
        default         steadyState;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default         none;
        div(phi,U)      bounded Gauss linearUpwind grad(U);
        div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda);
        div((nuEff*dev2(T(grad(U))))) Gauss linear;
    laplacianSchemes
        default         Gauss linear corrected;
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method          meshWave;
  10. fvSolution
    solvers
        p
            solver          GAMG;
            tolerance       1e-06;
            relTol          0.1;
            smoother        GaussSeidel;
        U
            solver          smoothSolver;
            nSweeps         2;
            tolerance       1e-08;
            relTol          0.1;
        nuTilda
            nSweeps         2;
            tolerance       1e-08;
            relTol          0.1;
    SIMPLE
        nNonOrthogonalCorrectors 0;
        residualControl
            p               1e-5;
            U               1e-5;
            nuTilda         1e-5;
    relaxationFactors
        fields
            p               0.8;
        equations
            U               0.7;
            nuTilda         0.7;
  11. Error Message
    smoothSolver:  Solving for Ux, Initial residual = 0.504513, Final residual = 0.0458849, No Iterations 52
    smoothSolver:  Solving for Uy, Initial residual = 0.506237, Final residual = 0.0415468, No Iterations 52
    #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    #1  Foam::sigFpe::sigHandler(int) at ??:?
    #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
    #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    #7  ? at ??:?
    #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
    #9  ? in /usr/lib/openfoam/openfoam2106/platforms/linux64GccDPInt32Opt/bin/simpleFoam
    #10  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #11  ? in /usr/lib/openfoam/openfoam2106/platforms/linux64GccDPInt32Opt/bin/simpleFoam
    Floating point exception (core dumped)
fran.cesc is offline   Reply With Quote
Old   October 19, 2024, 01:48
Jehan Sharook Rassdeen
Jehan99 is on a distinguished road
did you solve this problem?
Jehan99 is offline   Reply With Quote
external flow, openfoam2106, simplefoam; convergence;
Fluent do not use my velocity field(by UDF) to solve energy equation tangleiplus Fluent UDF and Scheme Programming 6 January 21, 2019 22:28
solve equation michaelsmit OpenFOAM Running, Solving & CFD 4 March 24, 2011 06:35
Solve Flow or VOF simultaneously ? Ramsey FLUENT 1 February 16, 2011 14:16
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 07:58
MAC method solve for pressure at boundry Ron Main CFD Forum 2 January 28, 2006 03:14
