simpleFoam error with output sigFpe::sigHandler |
October 11, 2021, 03:19 |
Muhammad Ahyar
Rep Power: 6 |
i tried to run the simpleFoam on my case which based on windaroundbuildings tutorial case. but when i execute the simpleFoam command, it turns out the error like this one. how to solve this error? Thanks in advance
October 12, 2021, 16:32 |
I am guessing here, but probably a divide by zero is found when reading the turbulence model. That probably means you have epsilon set as zero on a boundary or the internal field. If you make this a positive value then you should be able to get further. Cheers, Tom |
What variable should I output to get wall force? | Pauli | CFX | 6 | May 15, 2018 07:58 |
How to control output time of pressureTools functions? | Fluido | OpenFOAM Post-Processing | 1 | May 19, 2014 08:49 |
CGNS Output file parameters | ant0wn | SU2 | 1 | August 19, 2013 14:47 |
Questions about data output | aki_yafuji | OpenFOAM Running, Solving & CFD | 3 | September 9, 2010 01:59 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
