rhoCentralFoam sensible internal energy error? |
October 11, 2021, 00:47 |
Matthew
Rep Power: 5 |
Hi guys,
Currently I am running a double wedge case with rhoCentralFoam and faced an issue while running a case. Before running the case, I did some validations and grid convergences beforehand so the initial BCs and thermoproperties is not a problem I think. However once I moved onto the actual case, the calculation crashed at a certain timestep, which I have tried to change the relTol etc in fvsolution, reconstruct a few time interval ahead and run it, restart Ubuntu, lower the CFL number. Yet nothing worked out. At the time when the calculation crashed, before listing out the residual of e, which is internal energy, the message showed as below: Code:
Mean and max Courant Numbers = 0.0318184 0.190774 deltaT = 1e-09 Time = 0.0005743518088784423 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPBiCGStab: Solving for Ux, Initial residual = 4.40828e-07, Final residual = 4.26965e-12, No Iterations 1 DICPBiCGStab: Solving for Uy, Initial residual = 4.85822e-07, Final residual = 5.35129e-12, No Iterations 1 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpiexec detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[18653,1],2] Exit code: 144 -------------------------------------------------------------------------- |
October 11, 2021, 07:53 |
Rep Power: 7 |
we need your BCs, fvSchemes and CFL-Number in order to help you. |
October 12, 2021, 22:01 |
Matthew
Rep Power: 5 |
Sorry for the late reply. Here are the info:
U Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (1972 0 0); boundaryField { inlet { type fixedValue; value uniform (1972 0 0); } outlet { type inletOutlet; inletValue uniform (1972 0 0); value uniform (1972 0 0); } top { type supersonicFreestream; pInf 391; TInf 191; UInf (1972 0 0); gamma 1.4; value uniform (1972 0 0); } obstacle { type fixedValue; value uniform (0 0 0); } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 391; boundaryField { inlet { type fixedValue; value uniform 391; } outlet { type waveTransmissive; field p; psi thermo:psi; gamma 1.4; fieldInf 391; lInf 1; value uniform 391; } top { type zeroGradient; } obstacle { type zeroGradient; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 191; boundaryField { inlet { type fixedValue; value $internalField; } outlet { type inletOutlet; value $internalField; inletValue $internalField; } top { type inletOutlet; value $internalField; inletValue $internalField; } obstacle { type fixedValue; value uniform 300; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fluxScheme Kurganov; ddtSchemes { default backward; } gradSchemes { default cellLimited Gauss linear 1; grad(p) cellLimited Gauss linear 0.333; grad(e) cellLimited Gauss linear 0.333; } divSchemes { default Gauss vanLeer; div(phi,U) Gauss vanLeerV; div(phi,K) Gauss vanLeer; div(phi,e) Gauss vanLeer; div(phi,T) Gauss vanLeer; div(phid,p) Gauss vanLeer; div((nuEff*dev2(t(grad(U))))) Gauss linear; div(tauMC) Gauss linear; } laplacianSchemes { default Gauss linear limited 1; } interpolationSchemes { default vanLeer pos; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; flux(rhoU) vanLeer pos; dotInterpolate(S,tauMC) vanLeer pos; interpolate(muEff) vanLeer pos; interpolate(rho) vanLeer; } snGradSchemes { default limited 1; } // ************************************************************************* // |
October 14, 2021, 03:59 |
Rep Power: 7 |
here are some hints that might work: 1. CFL of 0.5 or 0.4 is quite high, you should rather use 0.2 or 0.3 with vanLeer. Even 0.1 is sometime necessary. 2. I have never used the supersonicFreeStream BC, what does it do excactly? 3. I think the main problem is the pressure, you are close to 0. You certainly will have some numerical oscillations and as soon as you reach a negative value the simulation will crash. 4. Also on the pressure: Why is it so low? This is basically vacuum. In vacuum you dont have a continuum. 5. What is vanLeer pos? First time I am seeing this. |
October 15, 2021, 00:44 |
#5 | |
Matthew
Rep Power: 5 |
Thanks for your reply!
1. I use such a high CFL number since the time step I am using is just 1e-9s, and for my validation case, which has a much aggressive phenomena, was working perfectly with a even higher CFL number. 2. For the supersonicFreeStream BC, according to OpenFOAM, it stated as: Quote:
3&4.The magnitude of the pressure is fixed as I am more or less likely replicating the hypersonic wedge cases done by Austin. 5. That's actually something weird for me at first. Cause I was unable to use vanLeer solely for those interpolations, then I looked into the source code: Code:
surfaceVectorField rhoU_pos ( fvc::interpolate(rhoU, pos, "reconstruct(U)") ); surfaceVectorField rhoU_neg ( fvc::interpolate(rhoU, neg, "reconstruct(U)") ); RhoCentralFoam detail |
October 15, 2021, 04:37 |
Rep Power: 7 |
I dont know what agressive phenomena are, but this might be the reason why vanLeer crashes. You are on the edge of stability, usually you need Co numbers of 0.1 to 0.3 for flows with high gradients. You have to chose between high accuracy or low calculation time.
You cant just use the vanLeer pos, because flux needs to be evaluated in both directions. I have just made some suggestions how those dicts may look like in here: Can rhoCentralFoam resolve turbulence? Please always look into the tutorials! Have you checked the knudsen number? If the flow is not a continuum, you cant use the navier stokes equations. |
October 15, 2021, 06:27 |
Matthew
Rep Power: 5 |
However, I am unable to proceed without defining the direction of flux. My advisor has stated that I must use full vanLeer or Minmod for interpolation and divschemes.
The designed flow I am using is a laminar flow, so I dont think turbulence plays a big part of the issue. And again, I am replicating the case done by Austin, which I am directly copying all initial boundaries which have been proved perfectly fine since 2012. |
October 15, 2021, 07:02 |
Rep Power: 7 |
Briefly said: Prescribing the direction is wrong. In compressible flow also backflow can occure.
I am not saying you should refer to his turbulence problem, just look at the schemes I am suggesting... At least read it when I am trying to help you. "Case by Austin" - you are not proving any information besides that an austin has calculated something. How am I supposed to know what exactly he was doing or if it was a peer reviewed journal article or just a youtube video? And if you would exactly replicate his case this error would not occure. |
October 15, 2021, 11:50 |
#9 |
Matthew
Rep Power: 5 |
Sorry for my attitude, I didnt mean to sound rude and I do really appreciate your help. Plus its nice to discuss with people about rhoCentralFoam as I am extremely new to CFD.
I did take some of your advices and currently running the case again and seeing how it goes. I hope it will work till the end but I also would like your help if anything happens in the future. |
October 16, 2021, 00:55 |
#10 |
Matthew
Rep Power: 5 |
Also I have a question, what is the difference between phid and phiv and phi? I cant really find a good explanation atm.
October 18, 2021, 04:20 |
#11 |
Rep Power: 7 |
Different solver use different implementations of phi. I dont know the definition of those, but you can look that up in the C++ guide:
https://cpp.openfoam.org/v9/ |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
