OpenFOAM (interFoam) crashing while solving k-epsilon model.
Old   October 1, 2021, 11:00
Default OpenFOAM (interFoam) crashing while solving k-epsilon model.
Legacy is on a distinguished road
Hello! I am new to OpenFOAM so this question might seem dumb. I want to simulate turbulent flow in an open channel. interFoam solves the case without any problems in laminar case but in turbulent condition it diverges. (high Courant Numbers). I get FPE error as something goes to infinity or division by zero.
I think it has something to do with boundary conditions in k, and epsilon but I could not figure it out.
fvSchemes:
|  \\    /   O peration     | Version:  v2106                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)   Gauss linearUpwind grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phi,epsilon) Gauss linear;
    div(phi,k) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    5;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
    "pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-5;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-07;
        relTol          0.05;
    p_rghFinal
        $p_rgh;
        relTol          0;
    U
        solver          smoothSolver; //
        relTol          0;
        "(k|epsilon|omega|UFinal|kFinal|epsilonFinal|omegaFinal)"
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-12;
        relTol           1.0e-2;
        maxIter          100;
PIMPLE
    momentumPredictor   no;
    nOuterCorrectors    1;
    nCorrectors         3;
    nNonOrthogonalCorrectors 1;
relaxationFactors
    fields
        "(p)"           0.3;
    equations
        "(U)"           0.7;
        "(k)"           0.3;
        "(epsilon)"     0.8;
        ".*"             1;
BlockMeshDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   0.1;
x1 4; // mainChannelLength
y1 2; // mainChannelWidth
z1 1; // mainChannelHeight
y2 3; // secondaryChannelLength
x2 1; // secondaryChannelWidth
z2 0.5; // secondaryChannelHeight
// Calculating edge coordinates
xx0 #eval{ 0.5*$x1+0.5*$x2 };
yy0 #eval{ $y1+$y2 };
xx1 #eval{ 0.5*$x1-0.5*$x2 };
zz0 #eval{ $z1-$z2 };
//MeshSiz 0.1; // Mesh Size in 2nd channel (spanwise)
//NcellS1 #eval{ std::floor( $x1/$MeshSiz )}; // Channel 1 number of cells (streamwise)
//NcellS2 #eval{ std::floor ($x2/$MeshSiz) }; // Channel 2 number of cells (spanwise)
vertices
//Block1
(0 0 0) // 0
($x1 0 0) // 1
($x1 $y1 0) // 2
(0 $y1 0) // 3
(0 0 $z1) // 4
($x1 0 $z1) // 5
($x1 $y1 $z1) // 6
(0 $y1 $z1) // 7
//Block2
($xx0 $y1 $zz0) //8
($xx0 $yy0 $zz0) //9
($xx1 $yy0 $zz0) //10
($xx1 $y1 $zz0) //11
($xx0 $y1 $z1) //12
($xx0 $yy0 $z1) //13
($xx1 $yy0 $z1) //14
($xx1 $y1 $z1) //15
blocks
hex (0 1 2 3 4 5 6 7) (320 160 80) simpleGrading (1 1 1) //Channel 1
hex (8 9 10 11 12 13 14 15) (400 80 40) simpleGrading (1 1 1) //Channel 2
edges
boundary
    outlet
        type patch;
        faces
            (6 2 1 5)
    inlet
        type patch;
        faces
            (0 4 7 3)
    bottomwall
        type wall;
        faces
            (0 1 2 3)
    leftwall2
        type wall;
        faces
            (8 12 15 11)
    atmosphere
        type patch;
        faces
            (4 5 6 7)
    rightwall
        type wall;
        faces
            (0 1 5 4)
    leftwall
        type wall;
        faces
            (2 6 7 3)
    // Box2
    c2bottom
        type wall;
        faces
            (8 9 10 11)
     c2atmosphere
        type patch;
        faces
            (12 13 14 15)
    c2outlet
        type patch;
        faces
            (9 13 14 10)
    c2rightwall
        type wall;
        faces
            (8 9 13 12)
    c2leftwall
        type wall;
        faces
            (11 10 14 15)
mergePatchPairs
(leftwall leftwall2)
ControlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         5;
deltaT          0.001;
writeControl    adjustable;
writeInterval   0.05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
maxDeltaT       1;
#sinclude   "sampling"
0/k
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.1;
boundaryField
    leftwall
        type            kqRWallFunction;
        value           uniform 0.1;
    rightwall
        value           uniform 0.1;
    bottomwall
        value           uniform 0.1;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0.1;
        value           uniform 0.1;
    outlet
        type            inletOutlet;
        value           uniform 0.1;
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.01;
        value           uniform 0.06;
    c2bottom
        value           uniform 0.1;
    c2atmosphere
        type            inletOutlet;
        value           uniform 0.1;
    c2outlet
        type            inletOutlet;
        value           uniform 0.1;
    c2rightwall
        value           uniform 0.1;
    c2leftwall
        value           uniform 0.1;
    defaultFaces
        type            empty;
0/epsilon
FoamFile
    version     2.0;
    format      ascii;
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
boundaryField
    leftwall
        type            epsilonWallFunction;
        value           uniform 0.1;
    rightwall
        value           uniform 0.1;
    bottomwall
        value           uniform 0.1;
    atmosphere
        type            inletOutlet;
        value           uniform 0.1;
    outlet
        type            inletOutlet;
        value           uniform 0.1;
    inlet
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    0.005;
        value           uniform 0.000055;
    c2bottom
        value           uniform 0.1;
    c2atmosphere
        type            inletOutlet;
        value           uniform 0.1;
    c2outlet
        type            inletOutlet;
        value           uniform 0.1;
    c2rightwall
        value           uniform 0.1;
    c2leftwall
        value           uniform 0.1;
    defaultFaces
        type            empty;
Legacy is offline   Reply With Quote
Old   October 1, 2021, 11:10
When I use adjustable time step, the time step goes to zero: Output here
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.576479, Final residual = 1.69443e-09, No Iterations 3
Phase-1 volume fraction = 0.999932  Min(alpha.water) = 0  Max(alpha.water) = 1.1816
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.999932  Min(alpha.water) = 0  Max(alpha.water) = 1.1686
DICPCG:  Solving for p_rgh, Initial residual = 0.99993, Final residual = 0.0219691, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 2.78473e-38, Final residual = 2.78473e-38, No Iterations 0
time step continuity errors : sum local = 2.34799e+44, global = -8.45321e+43, cumulative = -8.46412e+43
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libc.so.6
#3  Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
#8  ? at ??:?
#9  __libc_start_main in /lib64/libc.so.6
#10  ? at ??:?
Adjustable time step off:
Starting time loop
--> FOAM Warning :
    From function void Foam::particle::locate(const Foam::Vector<double> &, const Foam::Vector<double> *, int, bool, const Foam::string &)
    in file particle/particle.C at line 484
    Particle initialised with a location outside of the mesh when tracking from centre (0.0225 0.1975 0.0075) of cell 6324 to position (0.02 0.2 0.005)
Reading set description:
    gauge_1
    gauge_2
Courant Number mean: 0 max: 0
Interface Courant Number mean: 0 max: 0
Time = 0.001
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 1  Min(alpha.water) = 1  Max(alpha.water) = 1
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0480845, No Iterations 38
DICPCG:  Solving for p_rgh, Initial residual = 0.001251, Final residual = 5.07562e-05, No Iterations 24
time step continuity errors : sum local = 8.21433e-05, global = -1.06508e-05, cumulative = -1.06508e-05
DICPCG:  Solving for p_rgh, Initial residual = 0.0181754, Final residual = 0.000821557, No Iterations 38
DICPCG:  Solving for p_rgh, Initial residual = 0.0023616, Final residual = 9.93711e-05, No Iterations 24
time step continuity errors : sum local = 5.54347e-05, global = 7.24914e-06, cumulative = -3.4017e-06
DICPCG:  Solving for p_rgh, Initial residual = 0.00272227, Final residual = 0.00012654, No Iterations 17
DICPCG:  Solving for p_rgh, Initial residual = 0.000127637, Final residual = 8.15941e-08, No Iterations 44
time step continuity errors : sum local = 4.43924e-08, global = -1.19515e-09, cumulative = -3.4029e-06
DILUPBiCG:  Solving for epsilon, Initial residual = 0.432547, Final residual = 0.00151274, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 0.00501427, No Iterations 2
ExecutionTime = 2 s  ClockTime = 2 s
Courant Number mean: 0.933855 max: 10.6067
Time = 0.002
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1, Final residual = 6.31571e-09, No Iterations 3
Phase-1 volume fraction = 1  Min(alpha.water) = 0.999999  Max(alpha.water) = 1
DICPCG:  Solving for p_rgh, Initial residual = 0.0257119, Final residual = 0.00127956, No Iterations 41
DICPCG:  Solving for p_rgh, Initial residual = 0.00222235, Final residual = 9.88605e-05, No Iterations 29
time step continuity errors : sum local = 2.89055e-05, global = 4.45382e-06, cumulative = 1.05093e-06
DICPCG:  Solving for p_rgh, Initial residual = 0.0199581, Final residual = 0.00090856, No Iterations 38
DICPCG:  Solving for p_rgh, Initial residual = 0.00437537, Final residual = 0.000210576, No Iterations 28
time step continuity errors : sum local = 1.2806e-05, global = -1.03409e-06, cumulative = 1.68356e-08
DICPCG:  Solving for p_rgh, Initial residual = 0.0306757, Final residual = 0.00131807, No Iterations 16
DICPCG:  Solving for p_rgh, Initial residual = 0.00133985, Final residual = 9.60899e-08, No Iterations 71
time step continuity errors : sum local = 5.49774e-09, global = 2.29314e-10, cumulative = 1.70649e-08
DILUPBiCG:  Solving for epsilon, Initial residual = 0.709524, Final residual = 0.00573007, No Iterations 6
bounding epsilon, min: -0.207824 max: 500.884 average: 9.90857
DILUPBiCG:  Solving for k, Initial residual = 0.796152, Final residual = 0.00556545, No Iterations 6
bounding k, min: -58.4318 max: 204.832 average: 4.33867
ExecutionTime = 2.78 s  ClockTime = 3 s
Courant Number mean: 0.927321 max: 8.9843
Time = 0.003
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.99898, Final residual = 4.47903e-11, No Iterations 6
Phase-1 volume fraction = 0.999898  Min(alpha.water) = 0  Max(alpha.water) = 1
Phase-1 volume fraction = 0.999887  Min(alpha.water) = -0.0125567  Max(alpha.water) = 1.00597
DICPCG:  Solving for p_rgh, Initial residual = 0.106187, Final residual = 0.00498852, No Iterations 9
DICPCG:  Solving for p_rgh, Initial residual = 0.00227057, Final residual = 9.66437e-05, No Iterations 40
time step continuity errors : sum local = 1.0627e-05, global = 1.00609e-06, cumulative = 1.02316e-06
DICPCG:  Solving for p_rgh, Initial residual = 0.0188761, Final residual = 0.000923598, No Iterations 34
DICPCG:  Solving for p_rgh, Initial residual = 0.000584912, Final residual = 2.85582e-05, No Iterations 27
time step continuity errors : sum local = 5.54231e-06, global = 4.1449e-07, cumulative = 1.43765e-06
DICPCG:  Solving for p_rgh, Initial residual = 0.00464214, Final residual = 0.000228561, No Iterations 8
DICPCG:  Solving for p_rgh, Initial residual = 0.000243947, Final residual = 9.92472e-08, No Iterations 64
time step continuity errors : sum local = 1.81879e-08, global = 3.21452e-10, cumulative = 1.43797e-06
DILUPBiCG:  Solving for epsilon, Initial residual = 0.0321632, Final residual = 0.000107652, No Iterations 1
bounding epsilon, min: -5.00812 max: 311199 average: 135.697
DILUPBiCG:  Solving for k, Initial residual = 0.997182, Final residual = 0.00755244, No Iterations 9
bounding k, min: -3.71915 max: 4283.07 average: 155.914
ExecutionTime = 3.49 s  ClockTime = 3 s
Courant Number mean: 0.923043 max: 9.75704
Interface Courant Number mean: 0.00260689 max: 9.35186
Time = 0.004
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.491544, Final residual = 6.08724e-10, No Iterations 4
Phase-1 volume fraction = 0.999951  Min(alpha.water) = 0.582409  Max(alpha.water) = 1.00286
Phase-1 volume fraction = 0.999956  Min(alpha.water) = 0.582409  Max(alpha.water) = 1.03078
DICPCG:  Solving for p_rgh, Initial residual = 0.872382, Final residual = 0.0131008, No Iterations 2
DICPCG:  Solving for p_rgh, Initial residual = 0.00083191, Final residual = 3.21955e-05, No Iterations 7
time step continuity errors : sum local = 0.000684782, global = 0.000135832, cumulative = 0.00013727
DICPCG:  Solving for p_rgh, Initial residual = 2.76153e-05, Final residual = 1.21254e-06, No Iterations 43
DICPCG:  Solving for p_rgh, Initial residual = 9.4024e-07, Final residual = 9.41337e-08, No Iterations 24
time step continuity errors : sum local = 1.07063e-05, global = 1.06688e-06, cumulative = 0.000138337
DICPCG:  Solving for p_rgh, Initial residual = 1.0033e-05, Final residual = 4.62191e-07, No Iterations 43
DICPCG:  Solving for p_rgh, Initial residual = 4.45772e-07, Final residual = 9.3462e-08, No Iterations 18
time step continuity errors : sum local = 1.10211e-05, global = -1.91586e-06, cumulative = 0.000136421
DILUPBiCG:  Solving for epsilon, Initial residual = 0.129346, Final residual = 0.00122242, No Iterations 32
bounding epsilon, min: -731.285 max: 2.60303e+07 average: 947816
DILUPBiCG:  Solving for k, Initial residual = 0.785097, Final residual = 0.00508704, No Iterations 26
bounding k, min: -1975.57 max: 20642.1 average: 3522.04
ExecutionTime = 4.21 s  ClockTime = 4 s
Courant Number mean: 0.912524 max: 13.9602
Interface Courant Number mean: 0.00281132 max: 13.9602
Time = 0.005
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.538678, Final residual = 2.54492e-09, No Iterations 6
Phase-1 volume fraction = 0.999988  Min(alpha.water) = 0.81784  Max(alpha.water) = 1.0082
Phase-1 volume fraction = 0.999989  Min(alpha.water) = 0.797185  Max(alpha.water) = 1.04048
DICPCG:  Solving for p_rgh, Initial residual = 0.999924, Final residual = 0.0407437, No Iterations 4
DICPCG:  Solving for p_rgh, Initial residual = 0.000732188, Final residual = 2.99942e-05, No Iterations 31
time step continuity errors : sum local = 3171.82, global = 98.9218, cumulative = 98.9219
DICPCG:  Solving for p_rgh, Initial residual = 0.999999, Final residual = 0.0496443, No Iterations 20
DICPCG:  Solving for p_rgh, Initial residual = 0.0137463, Final residual = 0.000649829, No Iterations 26
time step continuity errors : sum local = 1.77798e+11, global = -2.06326e+09, cumulative = -2.06326e+09
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0484649, No Iterations 20
DICPCG:  Solving for p_rgh, Initial residual = 0.013821, Final residual = 9.27114e-08, No Iterations 80
time step continuity errors : sum local = 3.35538e+22, global = -1.09243e+21, cumulative = -1.09243e+21
DILUPBiCG:  Solving for epsilon, Initial residual = 1, Final residual = 0.00460737, No Iterations 2
bounding epsilon, min: -3.82187e+43 max: 1.414e+44 average: 9.1937e+39
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 0.000613373, No Iterations 3
bounding k, min: -1.30274e+34 max: 3.10203e+34 average: 8.83677e+29
ExecutionTime = 4.84 s  ClockTime = 5 s
Courant Number mean: 2.83494e+29 max: 3.80432e+32
Interface Courant Number mean: 6.81277e+22 max: 1.43842e+27
Time = 0.006
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.999997, Final residual = 2.32384e-09, No Iterations 22
Phase-1 volume fraction = 238364  Min(alpha.water) = 0  Max(alpha.water) = 1.81157e+10
Phase-1 volume fraction = 4.1998e+46  Min(alpha.water) = -8.49254e+66  Max(alpha.water) = 1.07193e+67
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0340628, No Iterations 4
DICPCG:  Solving for p_rgh, Initial residual = 3.21847e-84, Final residual = 3.21847e-84, No Iterations 0
time step continuity errors : sum local = 2.69341e+27, global = 1.21014e+27, cumulative = 1.21014e+27
DICPCG:  Solving for p_rgh, Initial residual = 9.47547e-83, Final residual = 9.47547e-83, No Iterations 0
time step continuity errors : sum local = 7.92964e+28, global = -3.68394e+27, cumulative = -2.47381e+27
DICPCG:  Solving for p_rgh, Initial residual = 1.01454e-82, Final residual = 1.01454e-82, No Iterations 0
time step continuity errors : sum local = 8.49029e+28, global = -6.65261e+27, cumulative = -9.12642e+27
DILUPBiCG:  Solving for epsilon, Initial residual = 0.0817333, Final residual = 0.000213674, No Iterations 26
bounding epsilon, min: -2.62723e+66 max: 9.34649e+66 average: 1.28677e+65
DILUPBiCG:  Solving for k, Initial residual = 1, Final residual = 801874, No Iterations 100
bounding k, min: -2.08023e+79 max: 2.32014e+80 average: 3.38051e+77
ExecutionTime = 5.6 s  ClockTime = 6 s
Courant Number mean: 3.94164e+29 max: 2.82322e+32
Interface Courant Number mean: 2.39755e+27 max: 7.8528e+30
Time = 0.007
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1, Final residual = 8.55191e-09, No Iterations 30
Phase-1 volume fraction = -6.03994e+74  Min(alpha.water) = -4.49584e+79  Max(alpha.water) = 6.07195e+72
#3  ? at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  __libc_start_main in /lib64/libc.so.6
#7  ? at ??:?
Floating point exception
interfoam, kepsilonmodel, openfoam, turbulence
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
