September 30, 2021, 05:42 |
Custom convergence criteria
costantino barro
Rep Power: 5 |
Hello everybody, do you think that there is a way to stop the simulation using a criteria that is not based on residuals?
I was wondering if there is a way to stop it when a certain force value is reached |
September 30, 2021, 05:57 |
Yann
Rep Power: 27 |
If you are using the ESI-OpenCFD branch (openfoam.com), you can use the runTimeControl function object : https://www.openfoam.com/documentati...e-control.html This function has been introduced in OpenFOAM-v3.0+ so you should have it in pretty much any version of the ESI-OpenCFD branch. I'm not aware of a similar functionality in the OpenFOAM foundation branch (openfoam.org) but I would be happy to learn about it if it exists. Cheers, Yann |
September 30, 2021, 07:28 |
costantino barro
Rep Power: 5 |
ok, thank you for the answer. Actualy the situation is a bit more complicated, cause I want to create a convergence criteria on the force, that is confronting the last n values of the force and if the difference is lower than a certain value the simulation is stopped.
September 30, 2021, 07:51 |
#4 | |
Yann
Rep Power: 27 |
Isn't it pretty close to one of the examples provided in the documentation?
September 30, 2021, 07:59 |
costantino barro
Rep Power: 5 |
You're right!.But on openFoam 9 I wasn't able to find that function
September 30, 2021, 08:38 |
Yann
Rep Power: 27 |
Yes, as I was saying earlier, this function is not available in the OpenFOAM foundation branch (openfoam.org), but only in the ESI-OpenCFD branch (openfoam.com)
Sorry but I don't have a solution for the foundation versions. Yann |
October 1, 2021, 11:15 |
Anup Singh
Rep Power: 6 |
Either go for the solution control library associated with your solver and after customizing attach it with your solver.
Or just get the solution control directly into your solver and modify the loops according to your needs. |
OpenFoam programming new convergence criteria | m_zanichelli | OpenFOAM Programming & Development | 2 | August 11, 2021 04:06 |
Time step size & convergence absolute criteria | yuitsang | FLUENT | 5 | April 15, 2013 04:27 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 17:13 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
convergence criteria | mujahid | FLUENT | 7 | March 6, 2004 15:06 |
