SimpleFoam does not converge, velocity bounded |
September 28, 2021, 09:44 |
Rep Power: 7 |
I have problem with a simulation and I hope you can help me. I have run a simulation in indoor environment (a room) with inlet condition from 8 diffussers and outlet condition at extraction grilles. I have used simpleFoam with RNG k-epsilon for turbulence model. The residual are stable, even if a little oscillating, residual for P is order of magnitued of 2*10^-2 and residual for U is 3*10^-3 (Image attached) I have monitored velocity in 8 points, using probes, the velocity is not constant but it is bounded and oscillating between 2 values, like a periodic phenomena (images attached). y+ values are: min 1e-2; max 7.6e+1; average 6e+0; I need to create a finer mesh near walls? log Check mesh, fvSchemes, fvSolution and Boundary conditions i have used are listed here: I have even tried the options after "//" MESH Code:
Mesh stats points: 3859442 faces: 10134517 internal faces: 9480040 cells: 3149724 faces per cell: 6.22739 boundary patches: 10 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2824568 prisms: 27670 wedges: 0 pyramids: 0 tet wedges: 940 tetrahedra: 0 polyhedra: 296546 Breakdown of polyhedra by number of faces: faces number of cells 4 1 5 2035 6 67942 7 10887 8 179 9 188981 10 4 12 23678 15 2180 18 659 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking geometry... Overall domain bounding box (-0.000251502 0 -0.00653899) (8.7855 7.23 2.88) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.84732e-15 6.82987e-16 -4.54469e-15) OK. Max cell openness = 3.74184e-16 OK. Max aspect ratio = 6.44698 OK. Minimum face area = 4.70551e-06. Maximum face area = 0.00337339. Face area magnitudes OK. Min volume = 4.622e-08. Max volume = 0.000185767. Total volume = 165.965. Cell volumes OK. Mesh non-orthogonality Max: 50 average: 8.5995 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.632 OK. Coupled point location match (average 0) OK. Code:
solvers { p { solver GAMG; tolerance 1e-07; relTol 0; smoother GaussSeidel; nPreSweeps 0; //3 nPostSweeps 2; //3 cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 1000; //10; 20; 30; mergeLevels 1; } U { solver PBiCGStab; preconditioner DILU; tolerance 1e-06; relTol 0; } k { solver PBiCGStab; preconditioner DILU; tolerance 1e-06; relTol 0.001; } epsilon { solver PBiCGStab; preconditioner DILU; tolerance 1e-06; relTol 0.001; } } SIMPLE { consistent yes; //no; residualControl { p 1e-4; U 1e-5; "(k|omega|epsilon)" 1e-5; } nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } relaxationFactors { fields { p 1; //0.3 } equations { U 0.7; "(k|omega|epsilon).*" 0.7; } } FVSCHEMES Code:
ddtSchemes { default steadyState; } gradSchemes { default cellMDLimited Gauss linear 0; //cellLimited leastSquares 1;//Gauss linear; //grad (p) Gauss linear 0.333; grad (U) cellMDLimited Gauss linear 0.333;//cellLimited leastSquares 1; limited cellLimited Gauss linear 1; // cellLimited leastSquares 1; grad(k) $limited; grad(epsilon) $limited; //sto rifacendo che per sbaglio avevo messo il cellLimited per grad(U) } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U) ; //bounded Gauss linearUpwind limited; turbulence bounded Gauss upwind; div(phi,k) $turbulence; div(phi,epsilon) $turbulence; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 1;//corrected;//orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default limited 1; //corrected; //orthogonal;// } Code:
This is before i have initialized the field with potentialFoam dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { diff1 { type swirlFlowRateInletVelocity; flowRate 0.044; rpm 82.8; value uniform (0 0 0); } diff2 { type swirlFlowRateInletVelocity; flowRate 0.034; rpm 103.89; value uniform (0 0 0); } diff3 { type swirlFlowRateInletVelocity; flowRate 0.043; rpm 26.32; value uniform (0 0 0); } diff4 { type swirlFlowRateInletVelocity; flowRate 0.045; rpm 36.36; value uniform (0 0 0); } diff5 { type swirlFlowRateInletVelocity; flowRate 0.045; rpm 79.05; value uniform (0 0 0); } diff6 { type swirlFlowRateInletVelocity; flowRate 0.044; rpm 85.30; value uniform (0 0 0); } diff7 { type swirlFlowRateInletVelocity; flowRate 0.039; rpm 105.35; value uniform (0 0 0); } diff8 { type swirlFlowRateInletVelocity; flowRate 0.048; rpm 29.88; value uniform (0 0 0); } outlet { type zeroGradient; // type pressureInletOutletVelocity; // value uniform (0 0 0); } walls { type noSlip; } EPSILON Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.013; boundaryField { walls { type epsilonWallFunction; value uniform 0.013; } diff1....diff8 { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.0014; value uniform 0.013; } outlet { type inletOutlet; //zeroGradient; inletValue $internalField; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0024; boundaryField { walls { type kqRWallFunction; //kLowReWallFunction; // value uniform 0.0024; } diff1...diff8 { type turbulentIntensityKineticEnergyInlet; intensity 0.05; value uniform 0.0024; } outlet { type inletOutlet; //zeroGradient; inletValue $internalField; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { walls { type nutUWallFunction; value uniform 0; } diff1...diff8 { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } } P Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { walls { type zeroGradient; } diff1...diff8 { type fixedFluxPressure; gradient uniform 0; value uniform 0; } outlet { type fixedValue; value uniform 0; } } 1)Do you know what I could modify to have a convergence? 2)Calculating a mean value for the velocity field is a good idea or it is not accurate? I know RANS calculate mean values so it is a mean of a mean. Thanks for the help Last edited by Andrea23; September 29, 2021 at 05:41. |
Fail to converge on triangular mesh using SimpleFoam | zizhou | OpenFOAM Running, Solving & CFD | 0 | January 30, 2020 06:26 |
no residual information for velocity in simpleFoam | rcastilla | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 09:43 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 22:34 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
