September 27, 2021, 21:12 |
"wallHeatTransfer" is not in OpenFOAM 8
HUO YUANZHI
Hello Everyone.
When I simulated by using buoyantPimpleFoam, I want to set the window by using "Fixed heat transfer coefficient". But when I simulate, there was some error that happened, Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 8 Exec : buoyantPimpleFoam Date : Sep 27 2021 Time : 18:11:18 Host : "ubuntu" PID : 9787 I/O : uncollated Case : /home/huo/OpenFOAM/OpenFOAM-8/air_condition_case/D307_with_window nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in transient mode with 1 outer corrector PIMPLE: Operating solver in PISO mode Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } --> FOAM Warning : From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] in file /home/huo/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/Field.C at line 232 Reading "/home/huo/OpenFOAM/OpenFOAM-8/air_condition_case/D307_with_window/0/T/boundaryField/Room" from line 48 to line 53 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. --> FOAM FATAL IO ERROR: Unknown patchField type wallHeatTransfer for patch type wall Valid patchField types are : 111 ( MarshakRadiation MarshakRadiationFixedTemperature advective calculated codedFixedValue codedMixed compressible::alphatJayatillekeWallFunction compressible::alphatWallFunction compressible::thermalBaffle1D<eConstSolidThermoPhysics> compressible::thermalBaffle1D<ePowerSolidThermoPhysics> compressible::turbulentTemperatureCoupledBaffleMixed compressible::turbulentTemperatureRadCoupledMixed convectiveHeatTransfer cyclic cyclicACMI cyclicAMI cyclicRepeatAMI cyclicSlip directionMixed empty energyJump energyJumpAMI entrainmentPressure epsilonWallFunction externalCoupled externalCoupledTemperature externalWallHeatFluxTemperature extrapolatedCalculated fWallFunction fanPressure fanPressureJump fixedEnergy fixedFluxExtrapolatedPressure fixedFluxPressure fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedMeanOutletInlet fixedPressureCompressibleDensity fixedProfile fixedUnburntEnthalpy fixedValue freestream freestreamPressure gradientEnergy gradientUnburntEnthalpy greyDiffusiveRadiation greyDiffusiveRadiationViewFactor inletOutlet inletOutletTotalTemperature interfaceCompression kLowReWallFunction kqRWallFunction mapped mappedField mappedFixedInternalValue mixed mixedEnergy mixedUnburntEnthalpy nutLowReWallFunction nutTabulatedWallFunction nutURoughWallFunction nutUSpaldingWallFunction nutUWallFunction nutkRoughWallFunction nutkWallFunction omegaWallFunction outletInlet outletMappedUniformInlet partialSlip phaseHydrostaticPressure plenumPressure porousBafflePressure pressure prghEntrainmentPressure prghPressure prghTotalHydrostaticPressure prghTotalPressure prghUniformDensityHydrostaticPressure processor processorCyclic rotatingTotalPressure sliced slip symmetry symmetryPlane syringePressure timeVaryingMappedFixedValue totalFlowRateAdvectiveDiffusive totalPressure totalTemperature turbulentInlet turbulentIntensityKineticEnergyInlet turbulentMixingLengthDissipationRateInlet turbulentMixingLengthFrequencyInlet uniformDensityHydrostaticPressure uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI uniformTotalPressure v2WallFunction variableHeightFlowRate waveSurfacePressure waveTransmissive wedge wideBandDiffusiveRadiation zeroGradient ) file: /home/huo/OpenFOAM/OpenFOAM-8/air_condition_case/D307_with_window/0/T/boundaryField/Window1 from line 57 to line 60. From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double] in file /home/huo/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 131. FOAM exiting Code:
FoamFile { version 2.0; format ascii; class volScalarField; location 0; object T; } dimensions [0 0 0 1 0 0 0]; internalField uniform 273.15; boundaryField { AirInlet1_4 { type fixedValue; value uniform 299.15; } AirInlet2_1 { type fixedValue; value uniform 299.15; } AirInlet2_2 { type fixedValue; value uniform 299.15; } AirInlet2_3 { type fixedValue; value uniform 299.15; } AirInlet2_4 { type fixedValue; value uniform 299.15; } AirOutlet1 { type zeroGradient; } AirOutlet2 { type zeroGradient; } Room { type externalWallHeatFluxTemperature; mode flux; q 0.0;//[W/m^2] kappaMethod fluidThermo; kappa none; value uniform 303.15; } Window1 { type wallHeatTransfer; Tinf uniform 303.15; alphaWall uniform 25.0; value uniform 303.15; } Window2 { type wallHeatTransfer; Tinf uniform 303.15; alphaWall uniform 25.0; value uniform 303.15; } Window3 { type wallHeatTransfer; Tinf uniform 303.15; alphaWall uniform 25.0; value uniform 303.15; } Window4 { type wallHeatTransfer; Tinf uniform 273.15; alphaWall uniform 25.0; value uniform 273.15; } AirConditionWall1 { type externalWallHeatFluxTemperature; mode flux; q 0.0;//[W/m^2] kappaMethod fluidThermo; kappa none; value uniform 303.15; } AirConditionWall2 { type externalWallHeatFluxTemperature; mode flux; q 0.0;//[W/m^2] kappaMethod fluidThermo; kappa none; value uniform 303.15; } AirInlet1_1 { type fixedValue; value uniform 299.15; } AirInlet1_2 { type fixedValue; value uniform 299.15; } AirInlet1_3 { type fixedValue; value uniform 299.15; } } |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
