2D Rarefied Flow Analysis with dsmcFoam
Old   September 25, 2021, 12:25
Default 2D Rarefied Flow Analysis with dsmcFoam
Shah Akib Sarwar
Shah Akib Sarwar is on a distinguished road
Hi guys,
I am a new user of dsmcFoam and I am trying to do a 2D simulation of a rocket plume impinging on the ground. I have been using the wedge15Ma5 tutorial to learn the details of the dsmcFoam solver, but there is one thing I am a bit confused about. Even though the tutorial is clearly for a 2D flow, as the z dimension is changed, the number of dsmc particles inserted into the domain changes as well. Although the final results do not vary very significantly, the contours for macroscopic properties (temperature, pressure etc.) seem to be much smoother with a larger z dimension (as a result, more dsmc particles inserted). Can anyone guide me on how to choose a proper z dimension for a 2D flow analysis with dsmcFoam (or even tell me whether it actually matters or not)?
Thank you!
Shah Akib Sarwar is offline   Reply With Quote
Old   October 3, 2021, 15:11
Shah Akib Sarwar
Any ideas?
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Plasma analysis in swirl flow yaledad FLUENT 0 February 8, 2013 17:43
Rarefied Flow through sudden expansion applemango Main CFD Forum 0 April 16, 2010 07:08
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
how to do this blade passage flow analysis ? manish CFX 2 January 16, 2006 04:58
