[overset] Overset mesh leaving background mesh domain |
Rep Power: 5 ![]() |
Hi everyone,
I'm interested in using OFs overset mesh functionality to simulate the closing of a valve. To do so, the overset mesh has to leave the domain of the background mesh, very much in the same way as done in this OF simulation: https://www.youtube.com/watch?v=TGj80RCSaLU with the code being available here: https://github.com/Vignesh-S-P/Analy...using-OpenFOAM I've read multiple times that the overset mesh has to be contained in the background mesh at all times and hence this kind of simulation should currently not be possible. And indeed the code only runs with v1806, but not later versions. Does anyone know why this is the case? Is it safe to use v1806 for this type of simulation, or was it removed because of some particular flaw? Thanks! |
Michael Alletto
Rep Power: 16 ![]() |
I think if it runs on v1806 it should run with minor changes in the dictionaries also on newer versions. What kind of error you get?
In this specific case, using newer versions leads to the time step size going to zero (I have not looked into why exactly this happens).
I found a few more comments indicating that the overset mesh is generally not allowed to leave the background mesh (and hence the simulations shouldn't be running in v1806 as well). Can anyone confirm this? |
Michael Alletto
I did some simulations with foam extend a while ago and with this version it was possible one mesh to leave the domain
Thanks for the hint! I might give it a try with the foam-extend version then.
overset mesh, valve simulation |
Overset simulation fails when using 2 close together overset + background mesh | quarkz | OpenFOAM Running, Solving & CFD | 0 | January 7, 2021 02:36 |
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca | insane | OpenFOAM Running, Solving & CFD | 0 | May 17, 2020 22:35 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
