Single processor run versus multi-processor run in OpenFOAM
Old   September 1, 2021, 23:10
Default Single processor run versus multi-processor run in OpenFOAM
Farzad Faraji
farzadmech is on a distinguished road
Dear Friends
I have been working on MPPIC solver(which I have developed extensively) and it works fine when I do single processor run, it works fine;
MPPICFoamFarzadd
but when I want to do multi-processor run, it fails;
echo "Mesh decomposition"
decomposePar
echo "Running"
mpirun -np 8 MPPICFoamFarzadd -parallel
and decomposeParDict is written below;
numberOfSubdomains 8;
method          scotch;
hierarchicalCoeffs
    n               (2 2 2);
    delta           0.001;
    order           xyz;
And code gives me this error;
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
rhoTrans_ i = 0
rhoTrans_ i = 1
Selecting packing model none
Selecting damping model relaxation
Selecting time scale model nonEquilibrium
Selecting isotropy model stochastic
Selecting time scale model isotropic
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
Creating finite volume options from "constant/fvOptions"
[1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] error in IOstream "IOstream" for operation primitiveEntry::read(const dictionary&, Istream&) end
[1]
[1] file: IOstream at line 0.
[1]
[1]     From function void Foam::IOstream::fatalCheck(const char*) const
[1]     in file db/IOstreams/IOstreams/IOstream.C at line 109.
[1]
FOAM parallel run exiting
[1]
MPI_ABORT was invoked on rank 1 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I really do not know why single processor works, but multi-processor does not work. Do you have any idea?
Thanks,
Farzad
farzadmech is offline   Reply With Quote
multi-processors, openfoam, scotch
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
