simpleFoam airfoil case not running for RAS
Old   August 26, 2021, 19:28
Default simpleFoam airfoil case not running for RAS
Jitish
JETZ is on a distinguished road
Hello everyone
I am trying to run an airfoil simulation in OpenFoam v8, the geometry was created and meshed in salome.
The checkMesh output from the terminal is attached as an image below.
Trying to run the base case as it is, changing the solver to kEpsilon and boundary values accordingly. The stock case gives the error output in the Error_1 image.
After changing the initial values accordingly to match the kEpsilon model, for this k=0.195 and epsilon = 0.554, nut=1e-6, executing simpleFoam did move forward to the second iteration at least. Still, the errors stop the simulation as can be seen in the Error_2 image below.
It should be noted, that when I change the simulationType to laminar in the momentumProperties and leave the model as kEpsilon, the simulation runs without any errors.
What other parameters should I look at to resolve this error?
This is a RAS incompressible simulation I am attempting.
Thank you in advance
JETZ is offline   Reply With Quote
Old   August 27, 2021, 04:56
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Your mesh check has an error and a warning. You should first remove at least the error.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 27, 2021, 11:04
Jitish
I know, I am still trying to see what is wrong with it.
But given the laminar simulation runs, I find it strange as to why RAS does not run.
Old   August 27, 2021, 13:04
Agustín Villa
agustinvo is on a distinguished road
The epsilon equation is quite sensitive to BC's, so if there are geometric problems you can have errors as you find. I suggest you, as @piu58 said, to check first the mesh.
agustinvo is offline   Reply With Quote
Old   August 28, 2021, 14:06
Jitish
Refined the mesh in certain areas, this is the output now from checkMesh checkMesh_2.png
Unfortunately, when running the simulation the error still persists, Error_3.jpg.
The values are still as stated above. Not sure what else to change.
Old   August 28, 2021, 14:19
piu58's Avatar
Uwe Pilz
It seems your solver has problems with turbulent kinetic energy. I recommend checking the b.c. for k and epsilon.
Uwe Pilz
airfoil 2d, openfoam-8, ras incompressible, simplefoam
NACA 0012 Airfoil, simpleFoam, Spalart Allmaras badwalgurpreet OpenFOAM Running, Solving & CFD 12 October 28, 2024 04:03
Turbulent flow over NACA0012 airfoil validation case (openfoam.com) Luke_M OpenFOAM Running, Solving & CFD 1 July 5, 2021 19:45
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
Problem in running simpleFoam tutorial Lana OpenFOAM Running, Solving & CFD 1 April 10, 2013 12:08
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
