convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam
Old   August 26, 2021, 06:01
Default convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam
ruanyg968tf is on a distinguished road
Dear foamers,
I am trying to simulate a 2D steady conjugate heat transfer film cooling case by using chtMultiRegionFoam in OpenFOAM v7. The region and the boundaries was shown in the following picture.
Mesh was generated using blockMesh. Fluid properties of air was used in the calculation. For both the mainstream and coolant, the velocities and temperatures were given at the inlets, and pressure values were given at the outlets. I used kOmega model for turbulence modeling. Besides, I have used thin boundary mesh to simulate the boundary layer profile. So at the solid surface, I used low Reynolds wall function for nut and k fields. I used upwind scheme for spacial discretization, and I used steadyState for temporal discretization.
The boundary conditions and fvSchemes and fvSolution was shown below:
fluid/T:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/fluid";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 450;
boundaryField
    mainStreamInlet
        type            fixedValue;
        value           uniform 450;
    mainStreamOutlet
        type            inletOutlet;
        inletValue      uniform 300;
        value           uniform 450;
    mainStreamUpWall
        type            zeroGradient;
    coolantInlet
        type            fixedValue;
        value           uniform 300;
    coolantOutlet
        type            inletOutlet;
        value           uniform 450;
    coolantBottomWall
        type            zeroGradient;
    fluid_to_solid1
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        kappaMethod     fluidThermo;
        kappa           kappa;
        Tnbr            T;
        value           $internalField;
    fluid_to_solid2
        kappa           kappa;
        Tnbr            T;
    frontAndBack
        type            empty;
fluid/U:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0/fluid";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (60 0 0);
boundaryField
    mainStreamInlet
        type            fixedValue;
        value           uniform (60 0 0);
    mainStreamOutlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    mainStreamUpWall
        type            noSlip;
    coolantInlet
        type            fixedValue;
        value           uniform (30 0 0);
    coolantOutlet
    coolantBottomWall
        type            noSlip;
    fluid_to_solid1
        type            noSlip;
    fluid_to_solid2
        type            noSlip;
    frontAndBack
        type            empty;
fluid/p_rgh:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    mainStreamInlet
        type            fixedFluxPressure;
    mainStreamOutlet
        type            prghPressure;
        p               uniform 101325;
    mainStreamUpWall
    coolantInlet
    coolantOutlet
        type            prghPressure;
        p               uniform 101325;
    coolantBottomWall
    fluid_to_solid1
    fluid_to_solid2
    frontAndBack
        type            empty;
fluid/p:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      p;
boundaryField
        type            calculated;
    frontAndBack
        type            empty;
fluid/k:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1.215;
boundaryField
    mainStreamInlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.015;
        value           uniform 1.215;
    mainStreamOutlet
        type            zeroGradient;
    mainStreamUpWall
        type            kLowReWallFunction;
        value           uniform 0;
    coolantInlet
        intensity       0.02;
        value           uniform 0.54;
    coolantOutlet
        type            zeroGradient;
    coolantBottomWall
        value           uniform 0;
    fluid_to_solid1
        value           uniform 0;
    fluid_to_solid2
        value           uniform 0;
    frontAndBack
        type            empty;
fluid/omega:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 402.492;
boundaryField
    mainStreamInlet
        type            turbulentMixingLengthFrequencyInlet;
        mixingLength    0.005;
        value           uniform 402.492;
    mainStreamOutlet
        type            zeroGradient;
    mainStreamUpWall
        type            omegaWallFunction;
    coolantInlet
        mixingLength    0.005;
    coolantOutlet
        type            zeroGradient;
    coolantBottomWall
    fluid_to_solid1
    fluid_to_solid2
    frontAndBack
        type            empty;
fluid/nut:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    mainStreamInlet
        type            calculated;
    mainStreamOutlet
        type            calculated;
    mainStreamUpWall
        type            nutLowReWallFunction;
        value           uniform 0;
    coolantInlet
        type            calculated;
    coolantOutlet
        type            calculated;
    coolantBottomWall
        value           uniform 0;
    fluid_to_solid1
        value           uniform 0;
    fluid_to_solid2
        value           uniform 0;
    frontAndBack
        type            empty;
fluid/alphat:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
boundaryField
    mainStreamInlet
        type            calculated;
    mainStreamOutlet
        type            calculated;
    mainStreamUpWall
        type            compressible::alphatWallFunction;
    coolantInlet
        type            calculated;
    coolantOutlet
        type            calculated;
    coolantBottomWall
    fluid_to_solid1
    fluid_to_solid2
    frontAndBack
        type            empty;
fluid/fvSchemes:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system/fluid";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss skewCorrected linear corrected;
divSchemes
    default             none;
    div(phi,U)          Gauss skewCorrected upwind;
    div(phi,h)          Gauss skewCorrected upwind;
    div(phid,p_rgh)     Gauss skewCorrected upwind;
    div(phi,K)          Gauss skewCorrected upwind;
    div(phi,k)          Gauss skewCorrected upwind;
    div(phi,epsilon)    Gauss skewCorrected upwind;
    div(phi,omega)      Gauss skewCorrected upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss skewCorrected linear;
laplacianSchemes
interpolationSchemes
    default         skewCorrected linear;
snGradSchemes
    default         corrected;
fluid/fvSolution:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    "rho.*"
        solver          diagonal;
    "p.*"
        solver          PBiCGStab;
        preconditioner  DIC;
        // preconditioner  DILU;
        tolerance       1e-12;
        relTol          0;
    "(U|e|h).*"
        solver          PBiCGStab;
        tolerance       1e-9;
    "(k|epsilon|omega).*"
        solver          PBiCGStab;
        // solver          smoothSolver;
        // smoother         symGaussSeidel;
        tolerance       1e-10;
PIMPLE
    nCorrectors      5;
    nNonOrthogonalCorrectors 3;
    momentumPredictor   yes;
    // transonic           yes;
    transonic           no;
    pMinFactor          0.1;
    pMaxFactor          2.0;
    residualControl
        p_rgh               1e-6;
        h                   1e-6;
        U                   1e-6;
        "(k|epsilon|omega)" 1e-6;
relaxationFactors
    fields
        p_rgh           1.0;
        rho             0.3;
    equations
        U               0.7;
        h               0.5;
        k               0.5;
        omega           0.3;
The residuals of the variables keeps fluctuating and finally get diverged. Besides, the pressure and temperature always hit the bounds during the calculation as shown in the following picture and snippet of the log file.
Time = 1
Solving for fluid region fluid
pressureControl: p max 416695
pressureControl: p min -753306
I have tried to change the discretization schemes to bounded version, however, the influence to the residual was limited. I also have tried to change the relaxation factors, but I could not find the proper combination that could stabilize the simulation. Do you know how to solve the problem? Any suggestions would be greatly appreciated. The case directory was attached at the end of the post, thanks.
log.chtMultiRegionFoam.zip
filmCoolingM0.5_2D.zip
ruanyg968tf is offline   Reply With Quote
Old   April 10, 2024, 03:23
prasad YVD
prasad YVD is on a distinguished road
Have you got the solution to this problem
prasad YVD is offline   Reply With Quote
chtmultiregionfoam, convergence failure, filmcooling
Solver for FIlm cooling problem arun1994 OpenFOAM Running, Solving & CFD 1 September 6, 2021 10:41
Film cooling problem arun1994 OpenFOAM 0 October 26, 2020 10:08
Why the convergence of a steady problem also need several time evolution steps ywem OpenFOAM Programming & Development 2 June 15, 2020 20:03
convergence problem of chtMultiRegionFoam in simulation of free convection sitajeje OpenFOAM Running, Solving & CFD 1 May 1, 2017 14:29
film cooling problem radu FLUENT 1 December 11, 2007 06:09
