What are the right BCs for a multi-solid-region problem? |
August 25, 2021, 16:54 |
Roberto
Rep Power: 5 |
Hi all,
I am trying to model a problem consisting of a solid (sub-divided into two regions) and a fluid. The two solid regions produce heat at different rates, and they have the same material properties. I dug into this forum for quite a while and found two posts: https://www.cfd-online.com/Forums/openfoam-pre-processing/211078-solid-solid-thermal-resistance-layer-thickness.html https://www.cfd-online.com/Forums/openfoam-solving/151469-boundary-condition-conjugate-thermal-heat-conduction.html They seem to agree on the fact that solid-to-solid interfaces should be modeled using compressible::turbulentTemperatureCoupledBaffleMix ed. However, my result doesn't look good at the interface (see attached figure). I have attached all the files. Any ideas of what is going on/suggestions are welcome! Thank you, Here is a snippet of the solid "heater0" changeDictionaryDict: Code:
heater0_to_heater1 { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod solidThermo; value uniform 298; } Code:
heater1_to_heater0 { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod solidThermo; value uniform 298; } Code:
// Heater 0 { name heater0CellSet; type cellSet; action new; source boxToCell; box (-0.004 -0.05 -0.1) (0.004 -0.025 0.1); } { name heater0; type cellZoneSet; action new; source setToCellZone; set heater0CellSet; } // Heater 1 { name heater1CellSet; type cellSet; action new; source boxToCell; box (-0.004 -0.025 -0.1) (0.004 0.0 0.1); } { name heater1; type cellZoneSet; action new; source setToCellZone; set heater1CellSet; } of-T-final-line.png post.zip |
August 31, 2021, 19:12 |
Solved using sample
Roberto
Rep Power: 5 |
When using the sample utility I have the possibility to select "cellPointFace" interpolationScheme.
The plots now look right. I am assuming, paraview plots the cell values by default or something like that. Anyway, I thought it was mentioning that the following post is related: chtMultiregionFoam--unequal temperature at coupled patches |
chtmultiregionfoam, multiregion, solid |
Negative initial temperature error (chtMultiRegionFoam) | jebin | OpenFOAM Pre-Processing | 60 | July 17, 2022 05:10 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 18:09 |
