September 3, 2021, 01:55 |
#21 | |
Arjun
Rep Power: 34 |
TruVOF is two phase system. In past they used to have documents on their site about it (if i remember correctly). |
September 3, 2021, 05:39 |
#22 | |||
Santiago Lopez Castano
Rep Power: 16 |
It seems to me that you are taking this thing with a bit too much passion, Do you work at Flow3D? BTW, What is wildkatze? |
September 6, 2021, 18:10 |
#23 | |
Andrea
Rep Power: 16 |
It would be very interesting indeed to have a link to something (a peer-reviewed paper ideally) describing your scheme.
September 13, 2021, 04:04 |
#24 | |
Arjun
Rep Power: 34 |
If you need extra terms to keep interface sharp then it is a trick whichever version of openfoam does it. You can switch it off but then the interface is smeared.
Is another multiphysics solver. We have been developing for almost 5 years now. |
September 13, 2021, 04:09 |
#25 | |
Arjun
Rep Power: 34 |
Wish to convince company to make it available to others and let the ideas about it more public. I might just make it an library that others can call it to calculate the volume fraction at the face. The paper shall be published about it but i am not sure how much i am allowed to write in detail. Though to Holger I tried to tell as much detail as I could to help him get this in openfoam. He has a student working on this idea. So at least I could provide him the global hint and ideas (not the fine details). There is certainly now someone working on similar ideas for openfoam. Hopefully it takes shape of library that others can directly use. This has very high probability. This week I am actually working on the library part and demonstrate the cases with higher courant (benchmark problems). |
September 13, 2021, 04:11 |
#26 |
Arjun
Rep Power: 34 |
This was actually tested again after i wrote in this thread just to see how the solver stands at the moment (current version).
The dt is based on maximum courant number (happens at the bottom of the bubble). |
September 18, 2021, 06:38 |
#27 |
Rep Power: 21 |
As far as i know there are no TrueVOF like solvers in OpenFOAM readily available. A VOF like interFoam has problems with high viscosity or density differences between the two media. Which often results in artificial velocities at the free surface. Using VOF for simulating a blob of highly viscous plastic/resin for example is not a good idea. And And another big "problem" are channel flows where the air is vented through a small outlet . And your water is moving hence much slower. This is for example typical in simulations used for injection molding. The "problem" here is that the air is moving near the speed of sound while the other fluid is an order of magnitude slower. And the air itself isn't really changing the fluid flow. Hence all commercial solvers for injection molding or casting are typically neglecting the air phase since it slows down the time step by an order of magnitude without much benefit to the user. They simply use particles to track pressure in these void regions.
Everything else said here still applies though. It is however beneficial for some applications to use such a VOF formulation. It should however be possible to implement this in OpenFOAM with simple methods. You need to check which cells belong to the interface or are near the interface and change the velocities there. And zero out everything in the air phase. You are still solving both phases and you need to be careful about mass conservation etc. Still a bit of work though |
Water diffusion into air | MGabr | CFX | 19 | September 3, 2023 20:06 |
multiphaseEulerFoam convergence problems | Stefanie.S.W. | OpenFOAM Running, Solving & CFD | 6 | August 28, 2019 05:15 |
Mass Transfer Between AIR and WATER | Math13570 | CFX | 12 | June 29, 2016 09:14 |
3D multiphase micro model: mixing effect of air and water at the T junction | ehsanfareed | FLUENT | 2 | March 22, 2015 23:29 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 2 | November 27, 2012 22:36 |
