Continue OpenFoam parallel run with different number of processors |
August 15, 2021, 07:33 |
Rep Power: 5 |
Hi all. I am running a large case on a cluster. I have a job completed on 16 cores up to a timestep of 10000s. I have reconstructed the data using reconstructPar and deleted all the processor directories (processor0, processor1...).
How do I continue the job to a timestep of 20000s using 32 cores instead? This is my script: Code:
decomposePar -force mpirun -np 16 renumberMesh -overwrite -parallel mpirun -np 16 overPimpleDyMFoam -parallel | tee log.solver I have edited the controlDict to start from the latestTime and the decomposeParDict has been changed for 32 processors now. After the decomposePar command, do I need to renumber the mesh again with 32 cores before running the solver itself? |
August 16, 2021, 04:53 |
Rep Power: 14 |
From a quick look at the source code (https://github.com/OpenFOAM/OpenFOAM...renumberMesh.C), I don't see any reference to the number of processors in the run in the coding, so I don't think that the way you have decomposed the problem matters. Instead, the utility is used to make the LDU matrix addressing more efficient - see eg this post.
August 17, 2021, 00:18 |
Rep Power: 5 |
Great, just needed some confirmation before submitting the job. Thank you!
decomposepar, parallel, reconstructpar |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 08:48 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 16:25 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
