August 12, 2021, 22:09 |
opaqueSolid radiation model in Fluid Region
Desh
Rep Power: 5 |
Hi formers,
I am testing radiations models and just wondering if opaqueSolid radiation model applicable for non-participating fluid region? The reason for this question is, I found opaqueSolid is much faster than both FvDom and ViewFactor models. Please see the attached radiation model file. The model runs just fine and I am not sure how the radiation is calculated (if it calculated) by the opaqueSolid. Absorptivity is set to 0 in the fluid. An explanation or any direction pointed out is much appreciated. Thank you. Dasith |
October 4, 2023, 00:18 |
Desh
Rep Power: 5 |
I could really use some clarity on this matter, I've follow this link
Adding Radiations in chtMultiRegionSimpleFoam which suggests that the OpaquSolid can be used in the fluidRegion. I have set up a simple model to test this, -a closed boxed -with a inlet and outlet in Xmin and Xmax -a frozen flow - two solid plates inside, one plate with constant temperature of 1000K. -radiation model to solid plates , OpaqueSolid -radiation model to fluid OpaqueSolid Now no matter what parameter I change in the radiationProperty and radiationBoundary file, the steady temperature of the plates stays the same. But when I adopt P1 model in the fluid region, things change. is it because OpequeSolid do not solve for G ? then how can one control the flux then ? utterly confused, would appreciate a point to start to resolve this mess!!! Thanks, Dasith |
chtmutiregionfoam, opaquesolid |
Error when solving p_rgh | bob94 | OpenFOAM | 0 | March 17, 2020 08:12 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
