simpleCar with porous media - v2012 and OF8 simulations do not match |
August 7, 2021, 16:36 |
Alan w
Rep Power: 6 |
My focus here is simulations with porous media defined by Darcy Forchheimer coefficients. There is a simpleCar tutorial in v2012; it simulates the airflow through a car radiator. When I run it there it gives reasonable results. Then I adapted it to run in OF8, which I prefer to use. In this case, it doesn't recognize the presence of the radiator. Also, under polymesh there is a 'sets' folder that doesn't appear in v2012. I'm not sure why. I need to understand why the OF8 version isn't running properly. Attached are images of the paraview outputs. The files that should pertain to the problem are fvOptions and topoSetDict. Here they are for v2012 and OF8, respectively: Hoping for advice, solutions and/or information! fvOptionsv2012 Code:
porosity1 { type explicitPorositySource; active true; explicitPorositySourceCoeffs { type DarcyForchheimer; selectionMode cellZone; cellZone porousZone; DarcyForchheimerCoeffs { //d d [0 -2 0 0 0 0 0] (5e7 -1000 -1000); d d [0 -2 0 0 0 0 0] (5e7 -5000 -5000); f f [0 -1 0 0 0 0 0] (0 0 0); coordinateSystem { origin (0 0 0); e1 (1 0 0); e2 (0 1 0); } } } } Code:
porosity1 { type explicitPorositySource; active true; explicitPorositySourceCoeffs { //type DarcyForchheimer; selectionMode cellZone; cellZone porousZone; type DarcyForchheimer; // D 100; // Very little blockage // D 200; // Some blockage but steady flow // D 500; // Slight waviness in the far wake // D 1000; // Fully shedding behavior //DarcyForchheimerCoeffs d d [0 -2 0 0 0 0 0] (5e7 -5000 -5000); f f [0 -1 0 0 0 0 0] (0 0 0); //d (50 -50 -50); //f (0 0 0); coordinateSystem { type cartesian; //added origin (0 0 0); //added coordinateRotation { //added //origin (0 0 0); type axesRotation; e1 (1 0 0); e2 (0 1 0); } } } } Code:
actions ( { name porousCells; type cellSet; action new; source boxToCell; box (2.05 0.4 -1) (2.1 0.85 1); } { name porousZone; type cellZoneSet; action new; source setToCellZone; set porousCells; } { name airIntake; type faceSet; action new; source patchToFace; patch body; } { name airIntake; type faceSet; action subset; source boxToFace; box (2.6 0.75 0)(2.64 0.8 0.1); } ); Code:
actions ( { name porousCells; type cellSet; action new; source boxToCell; sourceInfo { box (2.05 0.4 -1) (2.1 0.85 1); } } { name porousZone; type cellZoneSet; action new; source setToCellZone; sourceInfo { cellSet porousCells; } } { name airIntake; type faceSet; action new; source patchToFace; sourceInfo { //patch body; name "body"; } } { name airIntake; type faceSet; action subset; source boxToFace; sourceInfo { box (2.6 0.75 0)(2.64 0.8 0.1); } } ); |
