an error in WSL system--Foam::error::printStack(Foam::Ostream&) at ??:?
Old   August 1, 2021, 07:57
Question an error in WSL system--Foam::error::printStack(Foam::Ostream&) at ??:?
Dylan James
dylan_OF is on a distinguished road
hi guys:
I get an error when i try to run one of the cases in the tutorial within the WSL system
dylan@Dylan-DELL:~/OpenFOAM/OpenFOAM-v2006/tutorials/multiphase/interFoam/laminar/waves/solitary$ interFoam
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : _b45f8f6f58-20200629 OPENFOAM=2006
Arch   : "LSB;label=32;scalar=64"
Exec   : interFoam
Date   : Aug 01 2021
Time   : 18:29:18
Host   : Dylan-DELL
PID    : 519
I/O    : uncollated
Case   : /home/dylan/OpenFOAM/OpenFOAM-v2006/tutorials/multiphase/interFoam/laminar/waves/solitary
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.011
Time = 0.011
PIMPLE: iteration 1
Selecting waveModel Boussinesq
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3  Foam::waveModels::solitaryWaveModel::solitaryWaveModel(Foam::dictionary const&, Foam::fvMesh const&, Foam::polyPatch const&, bool) at ??:?
#4  Foam::waveModels::Boussinesq::Boussinesq(Foam::dictionary const&, Foam::fvMesh const&, Foam::polyPatch const&, bool) at ??:?
#5  Foam::waveModel::addpatchConstructorToTable<Foam::waveModels::Boussinesq>::New(Foam::dictionary const&, Foam::fvMesh const&, Foam::polyPatch const&) at ??:?
#6  Foam::waveModel::New(Foam::word const&, Foam::fvMesh const&, Foam::polyPatch const&) at ??:?
#7  Foam::waveModel::lookupOrCreate(Foam::polyPatch const&, Foam::fvMesh const&, Foam::word const&) at ??:?
#8  Foam::waveAlphaFvPatchScalarField::updateCoeffs() at ??:?
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() at ??:?
#10  ? at interFoam.C:?
#11  ? at ??:?
#12  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#13  ? at ??:?
Segmentation fault (core dumped)
the case is located at tutorials/multiphase/interFoam/laminar/waves/solitary
the version is openFOAM-v2006
I did not change any files
Ans i guess there is some kind of tool missing in WSL system, but i do not know what it is...
can anyone give me some advice? thank you very much!
Best,
dylan
dylan_OF is offline   Reply With Quote
solitary wave, wsl
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
Piece-wise compressible flow in pipe system jabier14 FLUENT 1 March 2, 2017 16:00
Cooling system design with CFX, Mechanics and system coupling gmingardo CFX 12 December 2, 2016 15:26
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 10:12
System Build Advice for FEA cycleback Hardware 1 February 8, 2013 21:53
