Unstable solution for pulsed heat source
Old   July 29, 2021, 18:13
Default Unstable solution for pulsed heat source
Sergey
seregaxvm is on a distinguished road
Hello!
I'm trying to simulate cooling of the pulse heater. Heating happens at high rate (819 [kW] in heater region) for a very short period of time (6 [µs]).
Unfortunately, simulation stops somewhere around 3 [µs] with either exceeded maxIter or negative temperature errors.
I've tried limiting minimum temperature in regions, subdividing the mesh, lowering deltaT value ... nothing seem to work.
What can I do to obtain a solution to this problem?
PS. Project may be run by issuing the command
make solve
PPS. I'm using scalarCodedSource defined in constant/heater/fvOptions to simulate a pulsed heat source.
PPPS. I it just me or scalarCodedSource does not work with MPI?
seregaxvm is offline   Reply With Quote
Old   July 30, 2021, 01:58
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
At first I would try to simulate just one pulse and understand how the physics need to be implemented.
At such a very short time, is it really necessary to have a transient solution here? Or may it be sufficient simply to add the amount of het in form of an increased temperature?
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 30, 2021, 05:27
Sergey
I did a simulation of the model in static case with 1000 [W] of heater power (run command make setup-stationary to setup stationary solution). Everything worked fine.
I need a transient solution because I need to investigate maximum temperature in the model in time and optimize the geometry.
Old   July 30, 2021, 18:15
Sergey
I seem to overcome this problem. Previously I used a separate heating region, which was uniformly heated in time. I removed this region and added Gaussian heat source:
heSource_i = A V_i \exp{\left(
-\frac{1}{2}\left(\frac{x_i-x_0}{\sigma_x}\right)^2
-\frac{1}{2}\left(\frac{y_i-y_0}{\sigma_y}\right)^2
-\frac{1}{2}\left(\frac{z_i-z_0}{\sigma_z}\right)^2
 \right)}
where A may be found from
A = \frac{P_{tot}}{\sqrt{2\pi}^3\sigma_x\sigma_y\sigma_z}
There may be some mistake there because I have to adjust A. Or may be it's due to discretization. I don't know.
Here's my codedSource for the heater:
transientHeatSource
    type        scalarCodedSource;
    name        sourceTime;
    active        true;
    scalarCodedSourceCoeffs
        selectionMode    all;
        fields        (h);
        codeInclude
        codeCorrect
        codeAddSup
                const scalar time = mesh().time().value();
                const scalarField& V = mesh_.V();
                const vectorField& C = mesh_.C();
                scalar xMean = 0, yMean = 0.00806, zMean = 0;
                scalarField& heSource = eqn.source();
                const scalar sigmaX = 1e-3;
                const scalar sigmaY = 1e-4;
                const scalar sigmaZ = 1e-3;
                const scalar freq = 200;
                const scalar amp = 6.3e6 * 0.130;
                const scalar impulse = 6e-6;
                const scalar T = 1/(2*Foam::constant::mathematical::pi*freq);
                const scalar func = fmod(time, T) / T;
                const scalar duty = impulse / T;
                const scalar Tot = func <= duty ? amp : 0;
                const scalar A = 0.8 * Tot / (std::pow(2*Foam::constant::mathematical::pi, 3.0/2.0) * sigmaX * sigmaY * sigmaZ);
                scalar heSourceTot = 0;
                forAll (heSource, i) {
                    scalar x = -std::pow((C[i].x() - xMean) / sigmaX, 2) / 2.0;
                    scalar y = -std::pow((C[i].y() - yMean) / sigmaY, 2) / 2.0;
                    scalar z = -std::pow((C[i].z() - zMean) / sigmaZ, 2) / 2.0;
                    heSource[i] -= A * V[i] * std::exp(x + y + z);
                    heSourceTot -= heSource[i];
                Pout<< "Adding heat source: " << heSourceTot << " [W] " \
                    " " << heSource.size() << " with center at (" << xMean << ";" << yMean << ";" << zMean << ")" << endl;
        codeConstrain
Old   August 1, 2021, 08:10
Eren
ErenC is on a distinguished road
AdjustableTimeStep seems active but you didn't spesify maxCo and maxDT. First, I would disable adjustableTimeStep and run, if it doesn't work lower the dt again etc.
Also, your first timestep is 5e-7 but your timePresicion is 1e-6. You might wanna lower that too.
ErenC is offline   Reply With Quote
Old   August 1, 2021, 08:37
Sergey
I ended up disabling it completely and doing a 10^{-6} timestep. Otherwise simulation may skip my heat source pulse.
Old   August 1, 2021, 14:42
Eren
Well, by using 1e-6 you'll get a trapezoidal'ish wave, if you need sinusodal wave you might wanna lower it.
Old   August 1, 2021, 15:35
Sergey
No, I use a square wave, so it's ok.
chtmultiregionfoam, heating, scalarcodedsource, stability problem
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
