flowType – extensional flow and obtaining extensional stress
Old   July 26, 2021, 14:06
Default flowType – extensional flow and obtaining extensional stress
Sourav Mandal
sourav90 is on a distinguished road
I can easily visualise the flowType in a nozzle geometry like in the attached figure 3. When I searched on this topic (extensional flow or extensional stress), there are important practical implications like in -
There is a functionObject called flowType that comes with both OpenFOAM-v2012 & OpenFOAM-8. The v8 provides the description:
PHP Code:
foamInfo flowType
File
/opt/OpenFOAM/OpenFOAM-8/src/functionObjects/field/flowType/flowType.H
Description
    Calculates
and writes the flowType of a velocity field.
The flow type parameter is obtained according to the following equation:
verbatim
|D| - |Omega|
lambda = -------------
D| + |Omega|
rotational flow
         0
simple shear flow
         1
planar extensional flow
\endverbatim
Examples
cannot find any tutorials using "flowType"
On this topic there are a few threads, but nothing very illuminating.
The polymer mixing example used a software called BEMflow that provides the "particle flow number" in the range 0 to 1 (rotational, shear, elongation), through (probably) a particle tracking method. In contrast, OPenFOAM provides the flowType that ranges between -1 to +1 (rotational, simple shear, planar extensional). For my application (3D bio-printing i.e. flowing hydrogel with living cells through nozzles), it would be very nice to know what portion of the fluid is experiencing how much of stress (shear & extension).
Now, my question is –
Is there a way to decouple extensional stress and shear stress & quantify these two parameters individually in OpenFOAM?
I'm not sure if this is the correct forum (maybe in programming & development?) but any kind of input would be very welcome
sourav90 is offline   Reply With Quote
elongation, extension, flowtype, shear stress, shearstress
obtaining significantly different Flow profiles after only changing Mesh size beratcagan OpenFOAM Running, Solving & CFD 5 July 1, 2020 13:28
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
is there a post processing keyword for obtaining mass flow rate and total mass? immortality OpenFOAM Post-Processing 29 July 6, 2013 02:08
3D Mesh validation for obtaining wall shear stress me03mao FLUENT 1 February 16, 2006 06:42
