Solving the Poisson Equation in complex situations |
July 26, 2021, 10:34 |
Rep Power: 7 |
Hello everybody
This is a question on electromagnetism as opposed to fluid dynamics. Imagine we have several regions of different dielectric constants with one region having a known charge distribution and some boundaries between regions having a preassigned potential and others having a known surface charge distribution. What then is the most efficient way in OpenFoam to solve the Poisson equation over the entire domain ? Or is finite element software more suitable for that task ? Thanks for your time reading this. Any reply appreciated. |
July 26, 2021, 12:02 |
Uwe Pilz
Rep Power: 15 |
The potential equation is best simulated by boundary elements. This is not included in OpenFoam.
Two advantages: - you need only to mesh the boundaries - it is easy the get high flux rates (current density for the flow field). This is always a problem with FEM / FDM. The principle is to cover the boundaries with some kind of point charges. The mathematisch behind the BEM avoid the singularity which arises if source and control points are identical.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
July 29, 2021, 00:54 |
Rep Power: 7 |
Thanks, Uwe, for the BEM tip. I was actually using the FEM software Elmer for over a year and I was aware it had A BEM model for the Poisson equation under their experimental and obsolete solvers section of their manual. So, I ignored it and instead implemented my version of their static electricity FEM solver. However, my research being on surface dielectric barrier discharge wing actuators also involves the continuity equations for 3 different ions as well as the Navier-Stokes equations for air. I now wonder if I better interface Elmer to OpenFoam as I had yet no luck in simulations of all these plasma equations using either Elmer or OpenFoam separately.
Regards, Marc |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 15:26 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 06:07 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
