how to convert .txt files to OpenFOAM format
Old   July 25, 2021, 15:48
Default how to convert .txt files to OpenFOAM format
Alan w
boffin5 is on a distinguished road
Recently I found a site showing some simulation case files for 0, constant and system, so I copied them as text (.txt) files. Now, I need to convert them to OpenFOAM format files. I thought the method would be easy to find, but after much searching, all I can find is some cryptic info, along with the comment, "just go write a program". But I'm not a programmer, and would appreciate some examples of how to do this.
btw, Thanks to all who have been an indispensable help to me, as I jump from problem to problem.
boffin5 is offline   Reply With Quote
Old   July 26, 2021, 01:44
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
OF accepts plain ASCII.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 26, 2021, 02:13
Daniel
DevilX is on a distinguished road
Hey Alan,
you don´t need any special file type for OF, so just name f.e. your velocity file "U" instead of "U.txt" and it works.
DevilX is offline   Reply With Quote
Old   July 28, 2021, 15:06
Default gave up prematurely
Alan w
Danke Schön and Thanks!
I appreciate your help, but I just used brute force and re-typed the files; thankfully they weren't too big. So I could have just renamed them to remove the .txt? What does f.e. mean?
Old   July 28, 2021, 15:16
piu58's Avatar
Uwe Pilz
Yes, that's it.
Uwe Pilz
OpenFOAM files into csv format kd55 OpenFOAM Post-Processing 4 May 16, 2023 04:58
[Technical] How to convert Corner-grid format to OpenFOAM mesh ELwardi OpenFOAM Meshing & Mesh Conversion 0 April 20, 2019 13:05
[Commercial meshers] starccm+ solution data convert into OpenFOAM format akshaybagi OpenFOAM Meshing & Mesh Conversion 1 June 2, 2017 06:09
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
