trouble running simpleCar case; fails at fieldAverage
Old   July 17, 2021, 17:18
Default trouble running simpleCar case; fails at fieldAverage
Alan w
boffin5 is on a distinguished road
Hi, in order to learn how to simulate car heat exchangers, I am trying to run the simpleCar tutorial that I found in v2012, by first converting it to OpenFoam8. I have focused on the latter version, and until now have been able to adapt v2012 cases.
The trouble arises when I run simpleFoam, and get the following error message:
Create time
Create mesh for time = 0
SIMPLE: Convergence criteria found
        p: tolerance 0.01
        U: tolerance 0.0001
        "(k|epsilon)": tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
Creating finite volume options from "system/fvOptions"
Selecting finite volume options model type explicitPorositySource
    Source: porosity1
    - selecting cells using cellZone porousZone
    - selected 10 cell(s) with volume 0.002
Porosity region porosity1:
    selecting model: DarcyForchheimer
    creating porous zone: porousZone
Starting time loop
--> FOAM FATAL IO ERROR:
keyword type is undefined in dictionary "/home/boffin5/cfdaero/simpleCar/system/controlDict/functions/fieldAverage"
file: /home/boffin5/cfdaero/simpleCar/system/controlDict/functions/fieldAverage from line 6 to line 16.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
     in file db/dictionary/dictionary.C at line 797.
It seems to fail on the term 'fieldAverage'. I have looked in the V8 tutorials for examples, and tried to incorporate them into the controlDict, which here shows my different attempts:
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         5000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      10;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    //#include "forceCoeffs"
    //#include "fieldAverage"
    #includeFunc fieldAverage(U, p, prime2Mean = yes)
    //#includeFunc fieldAverage      //(U, p, prime2Mean=yes)
    //#include "runTimeControls"
Apparently I have to add a line with #includeFunc, but I can't find the format that will make it work. In addition to the above, I also tried includeFunc with just U & p, but no dice. I would appreciate any ideas on how to resolve this problem.
boffin5 is offline   Reply With Quote
Old   July 18, 2021, 14:12
Tobermory will become famous soon enough
Alan
for details on fieldAverage, check out the Doxygen page: https://cpp.openfoam.org/v8/classFoa...e.html#details. This has an example of its usage.
However, I am confused - fieldAverage is a functionObject for doing time averaging of transient runs ... but you are trying use it in a simpleFoam run, which clearly makes no sense. Are you trying to get a spatial volume average? If so, you probably want something like: https://cpp.openfoam.org/v8/classFoa...e.html#details.
Tobermory is offline   Reply With Quote
Old   July 28, 2021, 14:50
Default found a improved version of simpleCar tutorial
Alan w
In the link below, the simpleCar tutorial from v2012 was modified and cleaned up. I was able to run the case.
https://develop.openfoam.com/Develop...4537a65abe171d
[mesh manipulation] Case diverges after running renumberMesh in parallel sita OpenFOAM Meshing & Mesh Conversion 1 June 26, 2019 08:24
Trouble with parallel runs cfdmarkus OpenFOAM Running, Solving & CFD 9 February 27, 2009 04:59
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
How to save a case running in background us FLUENT 0 July 6, 2005 11:43
