Solver - interFoam
Old   July 13, 2021, 03:16
Exclamation Solver - interFoam
Sohrab Askarli
askarli is on a distinguished road
While running the solver, I receive such an error presented below:
Unable to set reference cell for field p
Please supply either pRefCell or pRefPoint
file: /home/sohrab/OpenFOAM/sohrab-7/run/mydraft/case/system/fvSolution.PIMPLE from line 78 to line 81.
Please be informed that I replaced the stl files in a given tutorial with my own stl file and I didn't change anything in the controldict, only the name of the patches.
askarli is offline   Reply With Quote
Old   July 13, 2021, 03:35
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
The pressure needs a reference value, because the flow is equal at every level of p. You may add something like
    pRefCell        0;
    pRefValue       1;
to your solver in fvsolutions, for instance
PIMPLE {
    nOuterCorrectors 100;
    nNonOrthogonalCorrectors 1;
    nCorrectors         2;
    pRefCell        0;
    pRefValue       1;
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 13, 2021, 04:30
Sohrab Askarli
Herlizchen Dank, Uwe!
I inserted those, however, now I'm receiving another error like:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-3bcbaf946ae9
Exec   : interFoam
Date   : Jul 13 2021
Time   : 10:28:12
Host   : "sohrab-VirtualBox"
PID    : 7284
I/O    : uncollated
Case   : /home/sohrab/OpenFOAM/sohrab-7/run/mydraft/case
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh staticFvMesh
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::adjustPhi(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#4  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#5  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam"
Floating point exception (core dumped)
Old   July 13, 2021, 07:25
piu58's Avatar
Uwe Pilz
From which tutorial did you take your case?
Uwe Pilz
cfd, interfoam
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 4 September 25, 2023 08:10
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 2 January 14, 2020 14:23
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
