k Omega SST on a centrifugal fan
Old   July 7, 2021, 06:13
Default k Omega SST on a centrifugal fan
Fouch is on a distinguished road
Good morning guys,
I require your help to understand how to set correct values of k & omega for a centrifugal fan.
I understand that we have to calculate coefficient and add this values to boundary conditions but to do that we need the hydraulic diameter. In may case, I don't know know how to do because the model is according to the attached picture.
How should I do to get a correct hydraulic diameter with this inlet ?
Thank you in advance for your help.
Best regards,
Fouch is offline   Reply With Quote
Old   July 8, 2021, 11:56
Klaus
klausb will become famous soon enough
see page 10 of: https://ebmpapst.dk/wp-content/uploa...fugal-Fans.pdf
klausb is offline   Reply With Quote
Old   July 9, 2021, 04:35
Thank you for your reply !
Setting change from k omega to k omega SST bingo641 OpenFOAM Programming & Development 0 May 22, 2018 06:15
Centrifugal fan as a momentum source siw CFX 3 August 20, 2015 06:48
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 14:06
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
