[Chemistry] Lumped species in chemical reactions
Old   July 6, 2021, 07:40
Default [Chemistry] Lumped species in chemical reactions
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Howdy Foamers:
I have a question concerning definition of chemical reactions (as in ${CASE}/constant/reactions):
Question 1: How are the elements and species blocks used? What happens if the mechanism I am using as "lumped" species for which I cannot break down to their atom count (and hence I cannot get a definitive molar mass)?
Question 2: Another question is ... in the mechanism in question "abundant" reactive species are often omitted. So something like:
O + O2 + M -> O3 + M
will be shorthanded as
O -> O3
and the reaction rate will be lumped with the assumed concentrations of O2 and M, that is:
k_mod = k_original x [O2] x [M]
In this context, if the changes in [O2] and [M] can be effectively regarded as negligible for the duration of the simulation, can I still write the shorthanded reaction using the lumped reaction rate?
Thanks in advance, Gerry.
Gerry Kan is offline   Reply With Quote
How are chemical reactions stored after parsing? DanielW OpenFOAM Programming & Development 3 June 7, 2018 15:39
chemical species mass fraction Green_Horn STAR-CD 0 February 27, 2012 15:57
reference species rule for chemical reactions DaIN Main CFD Forum 0 October 12, 2011 08:25
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 12:11
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
