Wildcard ".*" before or after other boundaries? |
June 24, 2021, 05:50 |
Claudia
Rep Power: 5 |
Hey guys,
i was just wondering: if I use ".*" for my boundaries and want to specify e.g. the inlet differently, does the order matter? If yes, which should come first? |
June 24, 2021, 07:50 |
Herpes Free Engineer
Rep Power: 12 |
The safest way is to try it with a small case.
But, I would expect that the order would have an effect. I would be surprised if the order would not have any effect. I remember, the order was affecting the Lagrangian particle interaction models. So, for your specific case, I would put ".*" first, and then "inlet" condition after that.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
June 24, 2021, 08:10 |
Rep Power: 14 |
Check out this post, from a while back: Repeated keywords in the dictionary - useful info
The order DOES matter, as HPE says, but unfortunately it's not as simple as "the last instance counts" which was my initial gut feel. |
Periodic Interface: Symmetry Boundaries are not matching | mazhar16823 | Main CFD Forum | 2 | August 29, 2020 17:30 |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 11:04 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 13:11 |
