Luis
Rep Power: 0 ![]() |
Hi all,
I have two meshes related to flow in a permeable region. In membrane_1: the permeable region is on the bottom and the results are as expected. In membrane_2: the permeable region is on the top, so the result should be the opposite of. But for some reason i am getting the same result for both of them and I wonder why. Anyone can help me with that? Thanks in advance! Luis |
permeable wall, porositywall, porous cell zone, porous flow, porous media flow |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
