Using mapFields on a moving grid
Old   June 24, 2021, 03:59
Default Using mapFields on a moving grid
Reptider is on a distinguished road
Hello!
I have a situation where the grid changes at every time step so I need to map all fields to modified grid. There is only one external patch - movingWall.
Under certain conditions, this grid only changes in a few places that I can't determine explicitly.
mapFields requires patchMap and cuttingPatches. Which option should I use in my case?
Thank you!
Can I use only cuttingPatches? Will there be some problems on the new patch in places where deformation on the grid does not occur?
Reptider is offline   Reply With Quote
Old   June 28, 2021, 06:10
anonymous
simrego is on a distinguished road
Hi!
Why do you need to map? If the motion is made by a dynamicMesh lib, it'll map for you without any extra commands...
simrego is offline   Reply With Quote
IBM grid recognition in foam-extend 4.1 Guanzhu OpenFOAM 0 January 25, 2021 22:23
who have the education codes for moving grid? aiya Main CFD Forum 0 August 14, 2006 10:53
modification of fractional step for moving grid Wei Main CFD Forum 3 May 13, 2006 22:30
how use moving grid in fluent hamed FLUENT 3 October 26, 2005 04:09
Grid Moving Karthik Krishna FLUENT 4 February 23, 2005 08:57
